I updated to Ubuntu 14.04.1 and now I can't get into Grub Customizer.
I am getting the following errors:
chroot '/media/grub-customizer_recovery_root_mountpoint' grub-mkconfig couldn't be executed successfully. error message:
 Generating grub configuration file ...
Found linux image: /boot/vmlinuz-3.13.0-34-generic
Found initrd image: /boot/initrd.img-3.13.0-34-generic
Found linux image: /boot/vmlinuz-3.2.0-67-generic
Found initrd image: /boot/initrd.img-3.2.0-67-generic
Found linux image: /boot/vmlinuz-3.0.0-32-generic
Found initrd image: /boot/initrd.img-3.0.0-32-generic
Found linux image: /boot/vmlinuz-2.6.38-10-generic
Found initrd image: /boot/initrd.img-2.6.38-10-generic
Found linux image: /boot/vmlinuz-2.6.38-7-generic
Found initrd image: /boot/initrd.img-2.6.38-7-generic
cat: /video.lst: No such file or directory
/usr/sbin/grub-probe: error: failed to get canonical path of `'.
No path or device is specified.
Usage: grub-probe [OPTION...] [OPTION]... [PATH|DEVICE]
Try 'grub-probe --help' or 'grub-probe --usage' for more information.
Any ideas or help?
Braiam
  • 69,112
Im not familiar with grub customizr, but i assume it will call the underlying scripts, namely grub-mkconfig which might fail here.
Run the debug command from here Debian Bug 736928
sudo sh -x /usr/sbin/grub-mkconfig >/dev/null 2>grub-mkconfig.err
and look at grub-mkconfig.err, which showed me what the problem was for me, a customized 00_header file which was not valid anymore.
You might also be facing a problem where GRUB is installed into /boot/grub/i386-pc but the GRUB_PREFIX variable isnt set anywhere, just like mentioned here.
Fix this by making a backup of /usr/sbin/grub-mkconfig and add the following lines at the top, where the other variables are set
GRUB_PREFIX="/boot/grub/i386-pc"
export GRUB_PREFIX
You might just set the variable somewhere else, thats up to you.
x29a
  • 173
