I've upgraded from Ubuntu 14.04 to 16.04.2, recently. After having a failed upgrade, I reinstalled it using a DVD. Now after completing installation, when the DVD is ejected and I'm restarting, grub is coming up. I can't understand what I'm doing wrong. I followed the usual manual present at Ubuntu site. Please help.
output from lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sr0 11:0 1 1.5G 0 rom /cdrom
loop0 7:0 0 1.4G 1 loop /rofs
sda 8:0 0 465.8G 0 disk
├─sda4 8:4 0 1M 0 part
├─sda2 8:2 0 40M 0 part
├─sda5 8:5 0 7.9G 0 part [SWAP]
├─sda3 8:3 0 3G 0 part
├─sda1 8:1 0 500M 0 part
└─sda6 8:6 0 454.4G 0 part
output of blkid
/dev/sda1: LABEL="ESP" UUID="FA37-2A18" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="ff682bf3-7817-4b03-98dd-3771979e9eb2"
/dev/sda2: LABEL="DIAGS" UUID="AAA2-6116" TYPE="vfat" PARTLABEL="Basic data partition" PARTUUID="6ccc7ecf-6835-4622-99ad-727d741dfb71"
/dev/sda3: LABEL="OS" UUID="3AA3-6F37" TYPE="vfat" PARTLABEL="Basic data partition" PARTUUID="25f16079-8a5c-460c-aebc-1065ee3498e5"
/dev/sda6: UUID="9ac4d432-65b5-4897-9a56-0ed86acb9803" TYPE="ext4" PARTUUID="82cbf0c4-bfd7-4b4e-8b18-fa752181e21f"
/dev/sr0: UUID="2017-02-15-21-44-13-00" LABEL="Ubuntu 16.04.2 LTS amd64" TYPE="iso9660" PTUUID="15e2543d" PTTYPE="dos"
output of grub-install
ubuntu@ubuntu:~$ sudo grub-install /dev/sda1
Installing for i386-pc platform.
grub-install: error: failed to get canonical path of `aufs'.
output after formatting hard drive (as obtained from live dvd boot)
ubuntu@ubuntu:~$ lsblk
├─sda2 8:2 0 1K 0 part
├─sda5 8:5 0 3.9G 0 part [SWAP]
└─sda1 8:1 0 461.9G 0 part
ubuntu@ubuntu:~$
Final edit, for the straight to results solution.
Make sure you turn off UEFI completely in BIOS. i.e Use Legacy. If the option UEFI/Legacy appears on more than one BIOS menu, make sure Legacy is selected on all.
Boot into the Live CD
Do not reset or logout until you complete all of the steps or you will have to reinstall any program mentioned here as the Live CD will not save changes.
On the Live session install gparted, either through the GUI Software Center or with sudo apt-get install gparted
Open Gparted from the apps list and then select the hard drive on top right section.
With the drive selected delete all of the partitions on it by right clicking and selecting delete. Write those changes by clicking the check mark icon in the top menu
Once that is complete, select "Device" from the top text menu and "Create Partition Table"
When the pop up appears select ms-dos and write the changes. You can tell it to ignore any errors if you get any more popups.
Once that is done you have an MBR hard drive that is ready for Legacy booting.
Reboot and try installing Ubuntu again. Let the installer auto partition the hardrive, ,i.e Use Entire disk , with or without LVM.
m_krsic
  • 559
Check EFI boot path. When booting with secureboot on custom EFI image should be:
EFI\ubuntu\shimx64.efi
Are you using HP computer? Those are having some problem with uefi boot. Hp bug:
https://bugs.launchpad.net/linuxmint/+bug/1309395
Martin
  • 53
