148
What is the command update-alternatives used for?
Take this example:
sudo update-alternatives --install /usr/bin/java java /usr/local/java/jre1.7.0_09/bin/java 1
What does it do? How is it different from adding jdk to the path?
Let's say that I have run the command. How would I revert back to the original state?
Flimm
  • 44,031
It updates the links in /etc/alternatives to point to the program for this purpose. There's lots of examples, like x-www-browser, editor, etc. that will link to the browser or editor of your preference. Some scripts or system tools may want you to edit a file manually (e.g. configuration conflict in dpkg) and they'll look into the alternatives to give you the editor of choice. For java, this is the Java runtime environment - Oracle's, OpenJRE, etc.
The links in /etc/alternatives are just symbolic links. You can see them using for example
ls -l /etc/alternatives
Moreover, the regular /usr/bin binaries are also symlinks. E.g.:
ls -l /usr/bin/java
  lrwxrwxrwx 1 root root 22 Aug 14 10:33 /usr/bin/java -> /etc/alternatives/java
ls -l /etc/alternatives/java
  lrwxrwxrwx 1 root root 46 Aug 14 10:33 /etc/alternatives/java -> /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java
So, no PATH has to be modified. It just uses symbolic links.
gertvdijk
  • 69,427
While @gertvdjik's answer is a good explanation of how alternatives work at the lower level, it doesn't explicitly say how to revert the original state.
I find it easier to use the corresponding GUI galternatives which is available as a package. To install it, just run:
sudo apt-get install galternatives
Then managing alternatives becomes much easier. For java in particular, you have a lot of auxiliary binaries which you'll have to update and it's faster to overview them in the GUI.
mapto
  • 339
update-alternatives creates, removes, maintains and displays information about the symbolic links comprising the Debian alternatives system.
The generic name is not a direct symbolic link to the selected alternative. Instead, it is a symbolic link to a name in the alternatives directory, which in turn is a symbolic link to the actual file referenced. This is done so that the system administrator's changes can be confined within the /etc directory ...
Source and more details: man update-alternatives.
Aside: This master/slave terminology may be updated at some point.
As an example on Ubuntu 22.04, I can switch which Java I am using with sudo update-alternatives --config java:
$ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
0 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 auto mode 1 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 manual mode
  • 2 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081 manual mode
Press <enter> to keep the current choice[*], or type selection number:
So to answer the original questions:
  • update-alternatives updates symbolic links
  • from context, it looks like you meant PATH, however it does not change PATH or JDK, e.g. from Java 11 to Java 8 directly
  • it has nothing like history built in, so in the general case it's not possible to revert back to an original state. I'd expect you need to pick the most relevant alternative for the system state that works for you (in practice there's a good chance that you only have two alternatives when you first encounter this, so if you recently installed a second alternative that broke something for you, there's only one other to switch back to)
pzrq
  • 301
And update-alternatives can create a group to switch easily. For example javaw, java and javac needs to go together if java switches. Then javaw and javac should be installed as slaves of java. Or oc and kubectl (openshift client and kubernetes control) should go together, too. I have installed oc v3 and v4, and each version goes with its own kubectl. So I do:
sudo update-alternatives --install /usr/bin/oc3 oc /opt/oc3/oc 2 --slave /usr/bin/kubectl kubectl /opt/oc3/kubectl
sudo update-alternatives --install /usr/bin/oc4 oc /opt/oc4/oc 1 --slave /usr/bin/kubectl kubectl /opt/oc4/kubectl
So oc3 and its kubectl are prioritized.
