I was setting up android studio and got this
So I followed the answer here and used
sudo update-alternatives --set java /usr/local/java/jdk1.7.0_17/jre/bin/java
sudo update-alternatives --set javaws /usr/local/java/jdk1.7.0_17/jre/bin/javaws
But this gave me update-alternatives: error: alternative /usr/local/java/jdk1.7.0_17/jre/bin/java for java not registered; not setting
How can I fix this and get android studio working? I am have openJDK installed.
Qwertie
  • 906
  • 31
Most likely the exact 1.7.17 version is different now and the jdk1.7.0_17 does not exists, so use the interactive command to change the java or javaws alternative.
$ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                            Priority   Status
  0            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java   1061      auto mode
* 1            /usr/lib/jvm/j2re1.7-oracle/bin/java             316       manual mode
  2            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java   1061      manual mode
Press enter to keep the current choice[*], or type selection number: 1
$ sudo update-alternatives --config javaws
There are 3 choices for the alternative javaws (providing /usr/bin/javaws).
* 0            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/javaws   1071      auto mode
  1            /usr/lib/jvm/j2re1.7-oracle/bin/javaws             316       manual mode
  2            /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/javaws   1061      manual mode
  3            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/javaws   1071      manual mode
It's a lot less likely to make mistakes with this. :)
gertvdijk
  • 69,427
May be this can hepls to somebody: I had some problem. And i fix it changing symlink /etc/alternatives/java from openJDK to Oracle JDK (you must install it previous). To install Oracle JDK i used this instructions: http://www.webupd8.org/2012/01/install-oracle-java-jdk-7-in-ubuntu-via.html
