I'm trying to install java-13 on Ubuntu 18.04 following this tutorial.
I've installed java-11 before which is preventing these commands taking effect
  sudo mv jdk-13 /opt/
  sudo tee /etc/profile.d/jdk13.sh <<EOF
  export JAVA_HOME=/opt/jdk-13
  export PATH=\$PATH:\$JAVA_HOME/bin
  EOF
  source /etc/profile.d/jdk13.sh
type java command gives this
java is hashed (/usr/bin/java)
I guess this is due to some setting in some environment variables config file e.g. $HOME/.profile.
How do I know which file is overwriting my /etc/profile.d/jdk13.sh?
I also tried this command
export PATH=\$JAVA_HOME/bin:\$PATH
and got
java -version
Command 'java' is available in '/usr/bin/java'
The command could not be located because '/usr/bin' is not included in the PATH environment variable.
JJJohn
  • 201
You've "installed java-11 before"… using the same/a similar procedure which includes creating a shell script in /etc/profile.d? And is it still installed? Have a look at the output of type java–this should tell you whether the binaries like java are (still?) found in another directory ("first"). If you want to use different versions in parallel, have a look at man update-alternatives (see https://askubuntu.com/a/233192/525098) which explains how to cleanly switch between versions of the same (suite of) program(s). This can include auxiliary scripts which modify PATH, or you could use a script which actually sets the environment variables based on the location of the java binary.
