273
I would like to try a different video display driver, but I'm not sure which one I'm currently using.
What's the simple way to see what driver my system is using currently?
belacqua
  • 23,540
7 Answers7
278
Run lshw -c video, and look for the line with "configuration". The loaded driver is prefixed with "driver=". Example output:
  *-display
       description: VGA compatible controller
       product: Core Processor Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:45 memory:fd000000-fd3fffff memory:d0000000-dfffffff ioport:1800(size=8)
If you want more information about the loaded driver, run modinfo. Output of modinfo i915:
filename:       /lib/modules/2.6.35-24-generic/kernel/drivers/gpu/drm/i915/i915.ko
license:        GPL and additional rights
description:    Intel Graphics
author:         Tungsten Graphics, Inc.
... stripped information for saving space ...
depends:        drm,drm_kms_helper,video,intel-agp,i2c-algo-bit
vermagic:       2.6.35-24-generic SMP mod_unload modversions
Note that modinfo works on filenames and aliases, not on module names. The majority of the modules will have the same name for the module name and filename, but there are exceptions. One of them is nvidia.
Another way of using these commands in order to show you the file name of the driver would be:
modinfo -F filename `lshw -c video | awk '/configuration: driver/{print $2}' | cut -d= -f2`
When loaded, the command lsmod will show the nvidia module as loaded. modinfo nvidia will error out. Why? Because there is no module named "nvidia", it's just an alias. To resolve the alias you can use modprobe --resolve-alias nvidia. Or to get the whole modinfo in one command:
modinfo $(modprobe --resolve-alias nvidia)
Lekensteyn
  • 178,446
108
You could use the following command to see the currently used vga kernel driver:
lspci -nnk | egrep -i --color 'vga|3d|2d' -A3 | grep 'in use'
Example output for an ATI / AMD graphic card:
  • if the open source Radeon driver is used:
     Kernel driver in use: radeon
  • if the proprietary Fglrx driver is used:
     Kernel driver in use: fglrx_pci
Complete Output with lspci -nnk | grep -i vga -A3
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices [AMD] nee ATI Mobility Radeon HD 2400 [1002:94c9]
    Subsystem: Toshiba America Info Systems Device [1179:ff00]
    Kernel modules: fglrx, radeon
Available kernel modules you can see with lspci -nnk | grep -i vga -A3 | grep 'Kernel modules':
Note: This does not work in every case!
For a SiS 65x/M650/740 PCI/AGP VGA Display Adapter, there is no "Kernel driver in use" line:
lspci -nnk | grep -i vga -A2
01:00.0 VGA compatible controller [0300]: Silicon Integrated Systems [SiS] 65x/M650/740 PCI/AGP VGA Display Adapter [1039:6325]
    Subsystem: ASUSTeK Computer Inc. Device [1043:1612]
    Kernel modules: sisfb
and the available sisfb kernel module is not the loaded driver, because lsmod | grep sisfb has no output (sisfb is blacklisted). In this case also sudo lshw -c video | grep Konfiguration does not work. The output is:
   Konfiguration: latency=0
without any driver information.
BuZZ-dEE
  • 14,533
12
hwinfo --gfxcard
Look for the line starting by " Driver:" You may have to install hwinfo package first.
jarno
  • 6,175
The best information I've seen so far is in nouveau wiki. It can also help with non-nvidia cards: https://nouveau.freedesktop.org/wiki/Optimus/
This is xrandr --listproviders and sudo cat /sys/kernel/debug/vgaswitcheroo/switch. A lot of other useful info how to control power, outputs and offloading, etc.
inxi -G
inxi is a perl script to show system information in console; installed by default in Xubuntu at least.
jarno
  • 6,175
I have tried many ways without success, but this did work (Ubuntu 12.10):
/usr/lib/nux/unity_support_test --print
One reason is that I have Nvidia Optimus card which makes things harder, so I added optirun before the command.
user
  • 125
Open a terminal and type:
sudo apt-get install sysinfo
This is a handy little program that can tell you all ya need to know about your PC.
BuZZ-dEE
  • 14,533
