I am running Ubuntu 22.0.4.1 LTS x86_64 with 3 logically attached screens, as follows:
Screen 0: minimum 8 x 8, current 5600 x 1920, maximum 32767 x 32767
DP-0 connected 1080x1920+4520+0 right (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+ 74.97 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 3440x1440+1080+480 (normal left inverted right x axis y axis) 800mm x 335mm
3440x1440 59.97*+ 74.98 29.99
2560x1080 59.98 59.94 50.00
1920x1080 60.00 59.94 50.00
1720x1440 59.94
1680x1050 59.95
1440x900 59.89
1280x960 60.00
720x576 50.00
720x480 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected primary 1080x1920+0+0 left (normal left inverted right x axis y axis) 527mm x 296mm
1680x1050 59.95
1440x900 59.89
1280x960 60.00
720x576 50.00
720x480 59.94
For drivers,I am running the latest tested version of NVIDIA, as follows:
*-display
description: VGA compatible controller
product: TU104 [GeForce RTX 2070 SUPER]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:149 memory:53000000-53ffffff memory:40000000-4fffffff memory:50000000-51ffffff ioport:3000(size=128) memory:c0000-dffff
*-graphics
product: EFI VGA
physical id: 4
logical name: /dev/fb0
capabilities: fb
configuration: depth=32 resolution=1024,768
Upon boot, I am presented with 2 always but the HDMI-0 screen does not work without being messed with. Sometimes it's as simple as moving the orientation in the "Settings -- Display", or sometimes this command works:
sleep 5 && xrandr -d :1 --output HDMI-0 --auto
The third screen is always registered in NVIDIA Control, xrandr and Settings, but just not on ("black screen"). Looking for logs, I cannot locate an error (/var/log/syslog) as follows:
Aug 29 06:48:56 therion /usr/libexec/gdm-x-session[3560]: (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @1080x1920 +0+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=90}, DP-0: nvidia-auto-select @1080x1920 +4520+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=270}, HDMI-0: nvidia-auto-select @3440x1440 +1080+480 {ViewPortIn=3440x1440, ViewPortOut=3440x1440+0+0}"
Lastly, dmesg only resolves a few errors, such as:
[48033.822745] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
(HOwever at this time, the screen was working)
What logs, or process can I start using to diagnose why one screen occasionally doesn't work? I have noted going to sleep and unlocking will also sometimes resolve my issue.
