I have graphics card Radeon HD 7730, I have intel i5 processor running Ubuntu 14.04 LTS. Output of fglrxinfo follows:
display: :0  screen: 0
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) Ivybridge Mobile
OpenGL version string: 3.0 Mesa 11.0.2
Output of lshw -c video gives me:
 *-display
       description: VGA compatible controller
       product: 3rd Gen Core processor Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 09
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:29 memory:c1000000-c13fffff memory:b0000000-bfffffff ioport:4000(size=64)
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
This question has an answer lspci -nnk | grep -i vga -A3 | grep 'in use' for its output it gives:
Kernel driver in use: i915
Kernel driver in use: radeon
In my additional driver tab I see 3 drivers:
  1. Using X.ord Xserver -AMD? ATI dispaly driver wrapper from xserver-xorg-video-ati (open source, tested)
  2. Using Video driver from AMD graphics accelerators from fglrx-updates (proprietary)
  3. Using Video driver for AMD graphics accelerators from flgerx (proprietary)
The 3rd one is selected.
The response of lspci -k | grep -EA2 'VGA|Display' is
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
    Subsystem: Dell Device 0572
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Chelsea LP [Radeon HD 7730M] (rev ff)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
Questions:
  • I want to understand if my AMD card is served as graphics driver or i915?
  • If not how can I make it happen?
If you are using fglrx driver with dual graphics, you can check which adapter is in use In Catalyst Control Center, or by using a terminal command:
sudo aticonfig --pxl
Pilot6
  • 92,041
