38
Note: The legacy Skype for Linux application (v4.*) is now discontinued and was removed from Canonical’s partner repositories, so this question and its answers are obsolete. Please refer to a newer answer of our canonical Skype installation question.
I am receiving the following message while I am trying to install Skype:
nidhin@ubuntu:~$ sudo apt-get update
nidhin@ubuntu:~$ sudo apt-get install skype
Reading package lists... Done
Building dependency tree
 skype : Depends: skype-bin but it is not installable
E: Unable to correct problems, you have held broken packages
How can I fix this?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Nidhin
  • 381
10 Answers10
42
12.10 and newer
I had that same issue and what helped was to enable the 32-bit architecture by doing this:
sudo dpkg --add-architecture i386
sudo apt-get update
then I was able to install skype via the Canonical Partner Repository:
sudo add-apt-repository "deb http://archive.canonical.com/ $(lsb_release -sc) partner"
sudo apt-get update && sudo apt-get install skype
Willi
  • 618
33
First of all you have to enable i386 architecture before running the below commands on your Ubuntu 64 bit system.
Then run the below commands on terminal to install skype.
Ubuntu 13.10
sudo sh -c "echo 'deb http://archive.canonical.com/ saucy partner' >> /etc/apt/sources.list.d/canonical_partner.list"
sudo apt-get update
Ubuntu 14.04
sudo sh -c "echo 'deb http://archive.canonical.com/ trusty partner' >> /etc/apt/sources.list.d/canonical_partner.list"
sudo apt-get update
Avinash Raj
  • 80,446
I suggest to remove skype-bin first completely and install Skype as follows.
Run following commands in Terminal
sudo apt-get remove skype skype-bin
sudo apt-get install libxss1
wget http://www.skype.com/go/getskype-linux-ubuntu-64/skype-ubuntu-precise_4.1.0.20-1_amd64.deb
sudo dpkg -i skype-ubuntu*.deb
KK Patel
  • 19,753
 12.10 and above and in particular 17.04:
https://www.skype.com/en/download-skype/skype-for-computer/
Download the deb package
If it isn't installed already install gdebi :
sudo apt update && sudo apt upgrade
sudo apt install gdebi
then cd to the Downloads directory and run gdebi for the downloaded deb:
sudo gdebi –n skypeforlinux-64.deb
(Or for an approach that doesn't even require installation of any extra software) :
sudo dpkg -i skypeforlinux-64.deb
you may instead just right click on the downloaded file go into properties and set the default program to open this sort of file to gdebi (which is recommended in the meantime in 17.04) and then simply double click the file and when gdebi opens and finishes loading the file click install (you will be prompted for your password)
tatsu
  • 3,346
skype is not from ubuntu.it is a third party software supported by canonical foundation so edit your source.list using
$sudo gedit /etc/apt/source.list
then add the following link into your source list
deb http://archive.canonical.com/ubuntu $(lsb_release -sc) partner
deb-src http://archive.canonical.com/ubuntu $(lsb_release -sc) partner
$(lsb_release -sc) replace with your ubuntu name. Save it. Then update your repository using
$sudo apt-get update
now run the following command to install skype
$sudo apt-get install skype
this will install skype and skype.bin.
Braiam
  • 69,112
Try these commands:
cd /tmp
Source: http://www.tecmint.com/install-skype-4-1-in-ubuntu-xubuntu-linux-mint/
To Do
  • 15,833
  1. download skype package from here
  2. install it with double-click
  3. open nautilus in /usr/share/applications/
  4. edit skype.desktop (fix for sound issue) and replace line:
    Exec= skype %U with Exec=env PULSE_LATENCY_MSEC=30 skype %U
  5. drag skype.desktop and drop on unity bar (this will make opening same skype instance after closing window)
Full code for the .desktop file can be found at: skype.desktop
blade19899
  • 26,994
This is common problem in 64 bits for installing Skype
First a downgrade is required and done with the following: create the 'preferences' file:
sudo vi /etc/apt/preferences
and insert the following lines:
Package: *
Pin: release a=precise*
Pin-Priority: 2012
Pin-Priority must be greater than 1000.
Then you may downgrade the offending applications with:
sudo apt-get dist-upgrade
Then you may install packages that complained about dependencies, like
sudo apt-get install ia32-libs-multiarch, or sudo apt-get install ia32-libs.
Finally, you should remove the file you just created:
sudo rm /etc/apt/preferences
Now download Skype From Official website(skype.com ) for multi architecture
then open the downloded package from software center then you should able to install skype
While other answers here provide the correct way to install skype, you might still get the same error (I did).
Running aptitude install skype might be more useful in finding what's causing the problem.
One possible cause is a system upgraded from 14.04 to 16.04.
Some packages from ubuntu 14.04 have version numbers that when compared to those in 16.04 are considered "higher". E.g.:
  • ubuntu 14.04: libdrm2 2.4.67-1ubuntu0.14.04.1
  • ubuntu 16.04: libdrm2 2.4.67-1
When upgrading from 14.04 to 16.04 these packages are not upgraded (and won't be upgraded later either) because ubuntu thinks, for example, that 2.4.67-1ubuntu0.14.04.1 is greater than 2.4.67-1.
This causes problems when trying to install their i386 counterpart needed by skype because the i386 version wouldn't match the amd64 one already installed (which where leftovers from 14.04).
The same problem applies to libdrm-intel1, libdrm-radeon1, libdrm-nouveau2, libdrm-amdgpu1, libdrm-dev, libuv1. This list is not exhaustive.
This can be solved by creating a file (e.g. /tmp/pin.txt) containing:
Package: *
Pin: release n=*
Pin-Priority: 1001
and running:
sudo apt-get -o Dir::Etc::Preferences=/tmp/pin.txt dist-upgrade
Warning: This will install the version available in the repositories for ALL packages. Be careful if you have installed any packages from somewhere else (just make sure apt-get is not trying to downgrade anything when prompted for confirmation).
-1
Install Synaptic if you don't have it, Open it, then go to Edit > Fix Broken Packages. After that try to install Skype.
