I'm sure this is a duplicate candidate, but I have looked at the answer for 64bit 12.10, but it doesn't seem to work for my 13.10 installation.
I have enabled 32bit architecture, ie.
sudo dpkg --add-architecture i386
sudo apt-get update
I have added the canonical repository (and confirmed in "Software Sources" that it seems to be there).
sudo add-apt-repository "deb http://archive.canonical.com/ $(lsb_release -sc) partner"
I have tried cleaning the dependency tree up:
sudo apt-get clear
sudo apt-get autoclean
sudo apt-get -f install
sudo dpkg --configure -a
sudo apt-get -u dist-upgrade
And as far as I understand from the instructions linked above, no problems are reported. If I then try to install Skype:
nsa@quadrupod:~$ sudo apt-get install skype
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
skype : Depends: skype-bin
Not overly surprising, so I try installing skype-bin, as indeed is suggested and found to work in some answers:
nsa@quadrupod:~$ sudo apt-get install skype-bin
skype-bin:i386 : Depends: libasound2:i386 (>= 1.0.23)
Depends: libc6:i386 (>= 2.7) but it is not going to be installed
Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed
Depends: libqt4-dbus:i386 (>= 4:4.5.3) but it is not going to be installed
Depends: libqt4-network:i386 (>= 4:4.8.0) but it is not going to be installed
Depends: libqt4-xml:i386 (>= 4:4.5.3) but it is not going to be installed
Depends: libqtcore4:i386 (>= 4:4.7.0~beta1) but it is not going to be installed
Depends: libqtgui4:i386 (>= 4:4.8.0) but it is not going to be installed
Depends: libqtwebkit4:i386 (>= 2.2~2011week36) but it is not going to be installed
Depends: libstdc++6:i386 (>= 4.6) but it is not going to be installed
Depends: libx11-6:i386 but it is not going to be installed
Depends: libxext6:i386 but it is not going to be installed
Depends: libxss1:i386 but it is not going to be installed
Depends: libxv1:i386 but it is not going to be installed
Depends: libssl1.0.0:i386 but it is not going to be installed
Depends: libgl1-mesa-glx:i386 but it is not going to be installed
Recommends: sni-qt:i386 but it is not going to be installed
Recommends: libasound2-plugins:i386 but it is not going to be installed
OK, so I try to look up what these held/broken packages might be, according to this link and this link from here:
apt-mark showhold
returns nothing.
dpkg --get-selections | grep hold
and
dpkg -l | grep ^h
also returns nothing. So what is held?
I tried the suggestion here of using synaptic. It claims to fix broken packages, however to install Skype it wants to uninstall most of the system, including gnome-control-center, gnome-system-monitor, gnome-user-guide, the file lens, the clock (indicator-datetime), apt-utils, lib32gc1, (which is one of the dependencies apt-get thinks Skype needs amongst others on a long list. I don't see any obvious replacements on the much shorter list of what it thinks needs installing.
I also tried
sudo aptitude install skype.
with a similar result, it gives a list of stuff to uninstall that is so long it exceeds the normal terminal buffer and I had to pipe it to a file to read it. As above it includes things that do not sound wise to remove, including
73) gnome-bluetooth
74) gnome-calculator
75) gnome-contacts
76) gnome-control-center
77) gnome-control-center-datetime
78) gnome-control-center-signon
79) gnome-control-center-unity
80) gnome-disk-utility
81) gnome-font-viewer
82) gnome-icon-theme
83) gnome-icon-theme-symbolic
84) gnome-keyring
85) gnome-mahjongg
86) gnome-mines
87) gnome-orca
88) gnome-power-manager
89) gnome-screensaver
90) gnome-screenshot
91) gnome-session
92) gnome-session-bin
93) gnome-session-canberra
94) gnome-settings-daemon
95) gnome-sudoku
96) gnome-system-log
97) gnome-system-monitor
98) gnome-terminal
99) gnome-user-guide
100 gnome-user-share
and also wants to uninstall over 400 other packages. I would have thought I needed these..? Now it isn“t a long time since I installed ubuntu, but before I start over, has anybody got any ideas? Does it somehow think it should replace all 64bit stuff?
