I'm having trouble installing skype on a new 12.04 install (64 bit). Below are the results of three different attempts and the outputs. Any help will be greatly appreciated!
Download skype .deb file from skype website, I chose Ubuntu 12.04 (Multiarch). Open the deb file with Ubuntu Software Center and I get:
Error: Cannot install 'libasound2:i386'Synaptic Package Manager: I mark skype for installation (and the dialogue box for additional changes lists a ridiculously long list of packages to be removed! but anyway) I click OK, and get an error:
Could not mark all packages for installation or upgrade: The following packages have unresolvable dependencies. Make sure that all required repositories are added and enabled in the preferences. skype: Depends: skype-binTried the instructions from help.ubuntu but I get
$ sudo dpkg --add-architecture i386 dpkg: error: unknown option --add-architecture
But one way or another I think I sorted this out, so:
$ dpkg --print-foreign-architectures
i386
This is what my sources.list looks like:
deb http://archive.ubuntu.com/ubuntu precise main universe restricted multiverse
deb-src http://archive.ubuntu.com/ubuntu precise main universe restricted multiverse #Added by software-properties
deb http://security.ubuntu.com/ubuntu/ precise-security main universe restricted multiverse
deb-src http://security.ubuntu.com/ubuntu/ precise-security main universe restricted multiverse #Added by software-properties
deb http://cran.r-mirror.de/bin/linux/ubuntu precise/
deb http://archive.canonical.com/ precise partner
deb-src http://archive.canonical.com/ precise partner
I then run sudo apt-get update and sudo apt-get upgrade and finally:
$sudo apt-get install skype:
Reading package lists... Done
Building dependency tree
default-jre-headless : Depends: openjdk-6-jre-headless (>= 6b23~pre11-1ubuntu1~)
libatk-wrapper-java : Depends: default-jre or
java2-runtime
Recommends: libatk-wrapper-java-jni but it is not going to be installed.
skype : Depends: skype-bin
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I then try also:
$ sudo apt-get -f install
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I've also done clean,autoclean, dist-upgrade with no obvious effect.Not sure where to go from here!?
