Encountered an error while updating through Synaptic Manager. Subsequent updates gave the error at the bottom of the output. I'm a noob so any help is appreciated.
al@al:~$ sudo apt-get -f upgrade
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following NEW packages will be installed:
  libjack-jackd2-0:i386
The following packages have been kept back:
  linux-headers-generic skype
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/202 kB of archives.
After this operation, 493 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 310056 files and directories currently installed.)
Unpacking libjack-jackd2-0:i386 (from .../libjack-jackd2-0_1.9.8~dfsg.2-1precise1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libjack-jackd2-0_1.9.8~dfsg.2-1precise1_i386.deb (--unpack):
 './usr/share/doc/libjack-jackd2-0/buildinfo.gz' is different from the same file on the system
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
