Possible Duplicate:
How do I resolve unmet dependencies?
I can't do anything from Ubuntu Software Center or from Terminal
This is what i get from command line:
deus@comp:~$ sudo apt-get autoremove
[sudo] password for deus:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
firefox-globalmenu : Depends: firefox (= 18.0+build1-0ubuntu0.12.04.3) but it is not installed
E: Unmet dependencies. Try using -f.
deus@comp:~$ sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
firefox
Suggested packages:
latex-xft-fonts firefox-gnome-support
The following NEW packages will be installed:
firefox
0 upgraded, 1 newly installed, 0 to remove and 5 not upgraded.
1 not fully installed or removed.
Need to get 0 B/23.7 MB of archives.
After this operation, 49.7 MB of additional disk space will be used.
Do you want to continue [Y/n]? Y
(Reading database ... 203826 files and directories currently installed.)
Unpacking firefox (from .../firefox_18.0+build1-0ubuntu0.12.04.3_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/firefox_18.0+build1-0ubuntu0.12.04.3_i386.deb (--unpack):
trying to overwrite '/usr/lib/firefox/plugins', which is also in package adobe-flashplugin 11.2.202.261-0precise1
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for man-db ...
deus@comp:~$ sudo apt-get clean
deus@comp:~$ sudo apt-get check
firefox
Suggested packages:
firefox
Need to get 23.7 MB of archives.
Do you want to continue [Y/n]? y
Get:1 http://gr.archive.ubuntu.com/ubuntu/ precise-updates/main firefox i386 18.0+build1-0ubuntu0.12.04.3 [23.7 MB]
Fetched 23.7 MB in 1min 27s (271 kB/s)
Any ideas of what's going wrong?
EDIT/ANSWER TO COMMENTS
@Lucio I did what you said and here is the result.
deus@comp:~$ sudo dpkg -r firefox
dpkg: warning: there's no installed package matching firefox
deus@comp:~$ ^C
deus@comp:~$ apt-get -f install && sudo apt-get update && sudo apt-get upgrade
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
deus@comp:~$ sudo apt-get -f install && sudo apt-get update && sudo apt-get upgrade
firefox
Suggested packages:
firefox
0 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.
No apport report written because MaxReports is reached already
