I'm having issues with installing these two updates:
  • linux-generic-pae
  • linux-image-generic-pae
Getting the following errors every time I try to upgrade:
Setting up linux-image-3.2.0-35-generic-pae (3.2.0-35.55) ...
Internal Error: Could not find image (/boot/vmlinuz-3.2.0-35-generic-pae)
dpkg: error processing linux-image-3.2.0-35-generic-pae (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-generic-pae:
 linux-image-generic-pae depends on linux-image-3.2.0-35-generic-pae; however:
  Package linux-image-3.2.0-35-generic-pae is not configured yet.
dpkg: error processing linux-image-generic-pae (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-pae:
 linux-generic-pae depends on linux-image-generic-pae (= 3.2.0.35.40); however:
  Package linux-image-generic-pae is not configured yet.
dpkg: error processing linux-generic-pae (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
 linux-generic-pae
Any help would be much appreciated!
Aditya
  • 13,616
Try sudo apt-get purge linux-image-3.2.0-35-generic-pae then sudo apt-get install linux-image or sudo apt-get -f install I expect would clean up for you also after that first command.
Source: http://ubuntuforums.org/showthread.php?t=1036016
flickerfly
  • 7,509
