I had not installing any packages recently, but when i launched Software center, I saw a message: "Item cannot be installed or removed..."
/i am translating dumps from foreign language, so it might be not super precise with original/
Fixing software center catalog
Items cannot be installed or removed in 12.04 over 10.4
those solutions didnt work at all. I have some kind of paradox:
sudo apt-get install -f
tells me, that 2 packages will be installed: libdbus-glib-1-2:i386 libnspr4:i386 (and there is need to download 0 B/217 kB of archives) - strange; why it needs i386 deps in x64 arch system anyway?
I choose Y and it dumps:
(Reading database ... 300571 files and directories currently installed.)
Unpacking libdbus-glib-1-2:i386 (from .../libdbus-glib-1-2_0.98-1ubuntu1.1_i386.deb) ...
dpkg: processing error /var/cache/apt/archives/libdbus-glib-1-2_0.98-1ubuntu1.1_i386.deb (--unpack):
'./usr/share/doc/libdbus-glib-1-2/changelog.Debian.gz' is different from the same file on the system
Missing report of program apport, becouse MaxReports limit reached
Unpacking libnspr4:i386 (from .../libnspr4_4.9.5-0ubuntu0.12.04.1_i386.deb) ...
dpkg: processing error /var/cache/apt/archives/libnspr4_4.9.5-0ubuntu0.12.04.1_i386.deb (--unpack):
'./usr/share/doc/libnspr4/changelog.Debian.gz' is different from the same file on the system
dpkg-deb: error: subprocess paste was killed by signal (Interrupted stream)
There were errors while processing:
therefore I've removed /var/cache/ folder just in case;
then tried to install required deps independently:
sudo apt-get install libdbus-glib-1-2:i386
dumped:
You need to use "apt-get -f install", to repair following problems:
Following packages has broken dependencies:
libnss3:i386 : Requires: libnspr4:i386 (>= 4.8.6) but it will be not installed
E: Broken dependencies. Please try use "apt-get -f install" without packages (or give a solution).
so then I did:
sudo apt-get install libnspr4:i386
and it dumped:
libgconf-2-4:i386 : Requires: libdbus-glib-1-2:i386 (>= 0.78) but it will be not installed
both needs each one to allow install other one? paradox? i am in mess.
ps, if no solutions will be found to this I can copy packages from other working mirror pc /just dont want to clone whole partition/, which folder is used for storing this packages?
