I have a setup with AUX speakers and USB headphones connected to my Ubuntu 23.10 machine. I can set the default audio output device to the headphones, and some apps, like Spotify, seem to respect this choice. However, other apps like Chrome or Rhythmbox keep using the speakers instead.
I have tried installing pavucontrol as suggested in this question and switching application output devices from there. However, certain actions (e.g. switching a video to fullscreen) keeps changing back the audio output device from the headphones to the speakers. It's really frustrating.
Things I've tried:
  • Control audio with pavucontrol and resetting PulseAudio config (rm -r ~/.config/pulse) (question 1, question 2)
  • Various variations of disabling certain PulseAudio modules (question 1, question 2, this Reddit post)
  • Setting default PulseAudio sink (I only did this through pavucontrol, the headphones are selected as fallback in the "Configuration" tab, also selected through Gnome Settings). Running pactl get-default-sink also correctly shows the headphones: alsa_output.usb-Kingston_HyperX_7.1_Audio_00000000-00.analog-stereo
  • Restarting PulseAudio: pulseaudio -k && pulseaudio --start
  • Reinstalling PulseAudio: sudo apt install --reinstall pulseaudio; rm -r ~/.config/pulse; sudo reboot
However, none of this seems to work. I can select the headphones from Gnome Settings or pavucontrol, and e.g. Spotify works, but when I open a new video in Chrome for example, it just starts playing on the speakers. The only way of changing it to the headphones is through pavucontrol, or by going to the Gnome audio settings, selecting the speakers (now everything plays through the speakers) and then re-selecting the headphones (now everything plays through the headphones). Again, switching the video to fullscreen reverts the Chrome output back to the speakers (but not Spotify).
Notes
  • My system is pretty old and has gone through many updates. I believe the first Ubuntu version installed was 17.04.
  • The USB headphones are pretty old too (HyperX Cloud II), they seem to work fine (e.g. on Windows) but the DAC is pretty banged up at this point. Maybe a hardware problem?
Has anyone else encountered this issue before and has pointers on how to fix this? Or suggestions on what logs I should look at / debugging steps to take? Any help is much appreciated.
Edit
Adding some more system information that might help.
$ pactl list short cards
44  alsa_card.pci-0000_00_1b.0  alsa  # Built-in audio
45  alsa_card.pci-0000_05_00.1  alsa  # HDMI audio (disabled)
46  alsa_card.usb-0c76_USB_PnP_Audio_Device-00  alsa  # USB microphone
47  alsa_card.usb-Kingston_HyperX_7.1_Audio_00000000-00 alsa  # USB headphones
48  alsa_card.usb-046d_C922_Pro_Stream_Webcam_60A9E5DF-02   alsa  # Webcam microphone (disabled)
$ pactl list short sinks 49 alsa_output.pci-0000_00_1b.0.analog-stereo PipeWire s32le 2ch 48000Hz IDLE # Speakers 52 alsa_output.usb-Kingston_HyperX_7.1_Audio_00000000-00.analog-stereo PipeWire s16le 2ch 48000Hz RUNNING # Headphones
$ pactl info Server String: /run/user/1000/pulse/native Library Protocol Version: 35 Server Protocol Version: 35 Is Local: yes Client Index: 247 Tile Size: 65472 User Name: myname Host Name: myname-pc-ubuntu Server Name: PulseAudio (on PipeWire 0.3.79) Server Version: 15.0.0 Default Sample Specification: float32le 2ch 48000Hz Default Channel Map: front-left,front-right Default Sink: alsa_output.usb-Kingston_HyperX_7.1_Audio_00000000-00.analog-stereo Default Source: alsa_input.usb-0c76_USB_PnP_Audio_Device-00.mono-fallback Cookie: 5042:06db
Maybe the script I use in startup apps to be able to use analog line out helps:
#!/usr/bin/env bash
alsa force-reload
systemctl --user start pipewire-pulse.service
Source: Sound not working | Ubuntu 22.10 Tiger Lake-LP Smart Sound
