My Ubuntu 17.10 is connected via HDMI with my TV. HDMI ist the audio device I want always to use. Sometimes when the TV is turned off, Ubuntu switches the audio device tho semething else. When I turn on the TV again, I have to switch it back manually. How to prevent this automatic switching and set the audio device once and forever?
In /etc/pulse/default.pa comment out module-switch-on-port-available:
# load-module module-switch-on-port-available
Then restart.
- 4,043
You must deactivate all modules that start with module-switch-on-* in pulse audio service if you want to disable this behavior also with bluetooth and USB devices.
Ubuntu 18.04 and 20.04 LTS, for example:
module-switch-on-port-availablemodule-switch-on-connect
In a single instruction:
sudo sed -ri 's/^(load-module module-switch-on-.*$)/# \1/' /etc/pulse/default.pa
Then kill pulse audio or reboot:
pulseaudio -k
- 291
Yes, Witek's answer worked for me. I am new to Ubuntu (Xubuntu) so I didn't even know how to even comment out a line. So for people like me, here's a more detailed answer:
Go to your file manager and click "file system". Then find /etc/pulse/default.pa
Open that file using any text editor.
Putting a hash symbol # in front of a line of code is how you comment out a line. Put a hash in front of the line that reads:
When you click save, it will ask for your admin password. Enter it, restart and you're done.
