I want to install Chromium from the Linux Mint repositories in Ubuntu 20.04, to avoid snap.
This answer describes how to install Chromium from the Debian repository.
However, the Linux Mint repository usually hosts an updated version of Chromium compared to Debian (as of 12th January 2022, LM 20 repository contains Chromium 97, whereas Debian 11 repository has Chromium 90), and also, Debian security team might soon discontinue maintaining Chromium.
There are a couple of steps required to make this work and, fortunately, it's not too crazy. Here's how you can do this:
  1. Open Terminal (if it's not already open), and remove chromium snap package if you already have not.
    sudo apt purge chromium-browser
  2. Create an apt source file for the Mint repository:
    For Ubuntu 20.04:
    echo "deb http://packages.linuxmint.com una upstream" | sudo tee /etc/apt/sources.list.d/mint-una.list
    For Ubuntu 22.04 (and newer):
    echo "deb http://packages.linuxmint.com victoria upstream" | sudo tee /etc/apt/sources.list.d/mint-victoria.list
    for 24.04
echo "deb http://packages.linuxmint.com wilma upstream" | sudo tee /etc/apt/sources.list.d/mint-wilma.list
1. To prevent `NO_PUBKEY` you have to add the GPG key by this:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com A1715D88E1DF1F24 40976EAF437D05B5 3B4FE6ACC0B21F32 A6616109451BBBF2
1. Then update package lists by `apt`:
sudo apt update
1. Prevent installation of other packages by pin-file:
cat <<EOF | sudo tee /etc/apt/preferences.d/pin-chromium Package: * Pin: release o=linuxmint Pin-Priority: -1
Package: chromium Pin: release o=linuxmint Pin-Priority: 1000 EOF
1. Install `chromium`:
sudo apt install chromium
1. Open `chromium` and check the About:
![Mint's Chromium in 20.04][1]
<sup>**Note:** You may want to change the landing page, which is all about Mint Una </sup>
This will give you what you're looking for
matigo
  • 24,752
  • 50
  • 79
These directions are not necessarily incorrect. I do recommend using the vanessa repositories though. You can do this by doing the following:
  1. Open a Terminal.
  2. echo "deb http://packages.linuxmint.com vanessa upstream" | sudo tee /etc/apt/sources.list.d/mint-vanessa.list
  3. sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com A1715D88E1DF1F24 40976EAF437D05B5 3B4FE6ACC0B21F32 A6616109451BBBF2
NOTE: These same keys DO work. You may get a slight warning saying "W: http://packages.linuxmint.com/dists/vanessa/Release.gpg: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.", but as you probably know by now "W:" or warning signs aren't a big deal for the most part.
  1. sudo apt update (or "sudo nala update" if you use nala.)
  2. Again... prevent installation of other Linux Mint Repositories' packages by running the code above.
  3. sudo apt install chromium (or "sudo nala install chromium" if you use nala.)
Disclaimer: By using this process, you are pulling chromium as a .deb package. If you ever want to return to the snap format, you can either run the installation via snap or reverse this process.
Addendum to @matigo's answer updated to (K)Ubuntu 24.04 (not edited in their answer because it has too many pending edits).
Follow @matigo's answer but change steps 1 and 2 by the following ones:
  1. Create an apt source file for the Mint repository:
  2. To prevent NO_PUBKEY you have to add the GPG key by this:
    apt-key adv --recv-keys --keyserver keyserver.ubuntu.com A6616109451BBBF2
zx485
  • 2,865
sanzante
  • 101
