49
Are there any GUI alternatives to the Ubuntu Software Center with
  • Fast application loading/Low startup time
  • Fast search
  • Low weight/size
  • Application purchase facility
Raja G
  • 105,327
  • 107
  • 262
  • 331
15 Answers15
39
Yes, there is an alternative to the Ubuntu Software Center named appgrid. It's a very lightweight application center for Ubuntu and it will let you purchase applications too. You can install it in Ubuntu with these following commands:
sudo add-apt-repository ppa:appgrid/stable
sudo apt-get update
sudo apt-get install appgrid
It was only a 100KB download for me.
Comparison between appgrid and Ubuntu Software Center:
Feature                                                | appgrid  | Ubuntu Software Center
Programming language                                   | Python 3 | Python 2
Warm start to home screen                              | 2.7s     | 20s
Warm start to details screen (eg opening an apt: link) | 2.3s     | 30s
Full database build                                    | 58s      | 6min24
Initial database size                                  | 36.7MB   | 96.5MB
Memory usage after startup to home screen              | 20MB     | 53.6MB
Lines of code (including tests)                        | 5900     | 56960
You can sign in with Ubuntu One ID also:
Ubuntu One sign in screenshot
appgrid screenshot
Flimm
  • 44,031
Raja G
  • 105,327
  • 107
  • 262
  • 331
28
You can use synaptic , a front-end for apt-get.
Raja G
  • 105,327
  • 107
  • 262
  • 331
17
Yes. Try the Lubuntu Software Center. It is very fast and light-weight.
sudo apt-get install lubuntu-software-center
I noticed that deepin software-center is not on this list...
deepin-screenshot-1
deepin-screenshot-2
deepin-screenshot-3
Features:
  • There is a regularly updated list of featured applications on the home page. The list of recommendations are produced based on user ratings.
  • The Software Repository gives you a handy way to choose and install desired applications with just one click. With a powerful multi-threaded download back-end, they are available to you for fast download, limited only by your network connection.
  • Update manager helps you make sure your operating system has the latest and greatest software installed. All the updates are available for free!
  • Uninstalling applications that you no longer need gives you an opportunity to have a cleaner working environment.
  • Comes with 9 pre-installed colorful skins, so you can select one that brightens your day!
  • Cleanup cached packages to gain more space
  • Open download location and refresh application list
  • We have added official Ubuntu sources for fast downloads
sudo add-apt-repository ppa:noobslab/deepin-sc
sudo apt-get update
sudo apt-get install deepin-software-center
Reference:
blade19899
  • 26,994
13
You can try to familiarize yourself with the command lines: Searching:
apt-cache search wesnoth
This will often yield many results, so it is useful to pipe eg to less or to use grep to search further:
apt-cache search wesnoth |less
Search in all descriptions for FTP, show only the matches which have FTP in the package description
apt-cache search FTP |grep FTP |less
Installing:
sudo apt-get install wesnoth
Removing:
sudo apt-get remove wesnoth
johanvdw
  • 1,011
There is Muon Software Center (muon-installer), default Kubuntu software manager.
You can install it in Ubuntu, but it'll probably have a lot of Qt and KDE dependencies.
I recommend you aptitude, it's similar to apt-get but it has a very easy to use CLI.
You can always use synaptic, it's fairly easy to use and very powerful.
sudo aptitude is my personal favorite, used in the command line, very quick response on my 500mhz command line system.
sudo aptitude
You can also do it without sudo or root, but you can only view packages installed and search for packages.
agc
  • 563
Jared
  • 56
I noticed nobody mentioned gnome-software <code>gnome-software</code>
It will replace software-center in 16.04, but I quite like software-center itself.
If you just want to search for Ubuntu applications in the Ubuntu official repositories, you can browse the official "Apps" website: https://apps.ubuntu.com/
Here you can also quicly see screenshots and reviews for every app.
To install an app, you can just click the "Available in the Software Center" button in app detail page, using the "apt:" protocol.
Here you can find info about apt links:
Or you can just install the found package with synaptic or directly with command line sudo apt-get install <name>, as reported in other answers.
Stefano
  • 2,394
You can try this:
Appnr : A web based software center
This is a website which primarily uses the functionality of apt-url to install apps on Ubuntu.
More details find here : How to Download??
Praveenks
  • 152
there is bauh store:
Graphical user interface for managing your Linux applications. Supports AppImage, Debian packages, Flatpak, Snap and native Web applications
to install read the installation guide
panel image from github
matan h
  • 117
If you have enabled online search on Unity, your able to search for an app in the Unity App scope, under « More Suggestions ». Right click on the app and you'll see the description (aka Preview mode). And you've the ability to install the app from here, very quickly
Winael
  • 256
You can use aptitude (if it counts). It should be pre-installed with your system but otherwise you can install it using apt-get :
apt-get install aptitude
And then it should be fine.
Note: I didn't do any research before writing this answer, so some parts can be wrong.
Nano
  • 103
There is also mintinstall, avaliable from the Linux Mint repos
See How to add Linuxmint repositories to Ubuntu?
There is gnome-packagekit as well. It is easy to install multiple apps at once with the checkboxes. If you have used gnome-app-install (Add/Remove) on version prior to 9.10, it works it pretty much the same way.
