57
If using UEFI Please see this question, "Can I boot memtest86+ if I'm using UEFI?"
After having installed the 64bit version of Ubuntu 12.04 on my Lenovo B570 I ran into the same problems I had when installing 11.10 with Grub not playing nicely with a uEFI system. I used the same technique as last time to solve the problem (using a Super Grub Disc LiveCD session to repair Grub) and my system happily dual boots between Ubuntu and Windows 7
However now when I boot up the Grub menu only displays
  • Ubuntu, with Linux 3.2.0-24-generic
  • Ubuntu, with Linux 3.2.0-24-generic (recovery mode)
  • Previous Linux versions
  • Windows 7 (loader) (on /dev/sda1)
  • Windows Recovery Environment (loader) (on /dev/sda4)
I no longer see the option to use Memtest86+ which was there previously, having checked in the Ubuntu Software Center I can see that the package is installed, but how to I make the option to run it once again appear in the Grub menu?
I've tried:
sudo update-grub
which doesn't make any difference.
sudo chmod +x /etc/grub.d/20_memtest86+
results in:
chmod: cannot access /etc/grub.d/20_memtest86+': No such file or directory
and entering
ls /etc/grub.d/
results in:
00_header        10_linux      30_os-prober  41_custom
05_debian_theme  20_linux_xen  40_custom     README
coversnail
  • 6,406
6 Answers6
34
Try opening a terminal and running
sudo update-grub
Check to see if it's there
grep memtest /boot/grub/grub.cfg
Just done the same as I had it disabled
$ cat /boot/grub/grub.cfg | grep memtest
$ sudo chmod +x /etc/grub.d/20_memtest86+ [sudo] password for hob:
$ sudo update-grub Generating grub.cfg ... Found linux image: /boot/vmlinuz-3.2.0-24-generic Found initrd image: /boot/initrd.img-3.2.0-24-generic Found linux image: /boot/vmlinuz-3.2.0-23-generic Found initrd image: /boot/initrd.img-3.2.0-23-generic Found memtest86+ image: /boot/memtest86+.bin Found Ubuntu 11.10 (11.10) on /dev/sda6 Found Trisquel 5.5 (5.5) on /dev/sda8 Found Ubuntu 12.04 LTS (12.04) on /dev/sda9 done
BEGIN /etc/grub.d/20_memtest86+
menuentry "Memory test (memtest86+)" { linux16 /boot/memtest86+.bin menuentry "Memory test (memtest86+, serial console 115200)" { linux16 /boot/memtest86+.bin console=ttyS0,115200n8
END /etc/grub.d/20_memtest86+
You could try creating the file if it's not there, using nano in a terminal
sudo nano /etc/grub.d/20_memtest86+
or with a gui editor
gksudo gedit /etc/grub.d/20_memtest86+
Fill it with
#!/bin/sh
set -e
if [ -f /usr/lib/grub/grub-mkconfig_lib ]; then . /usr/lib/grub/grub-mkconfig_lib LX=linux16 elif [ -f /usr/lib/grub/update-grub_lib ]; then . /usr/lib/grub/update-grub_lib LX=linux else
no grub file, so we notify and exit gracefully
echo "Cannot find grub config file, exiting." >&2 exit 0 fi
We can't cope with loop-mounted devices here.
case ${GRUB_DEVICE_BOOT} in /dev/loop/*|/dev/loop[0-9]) exit 0 ;; esac
prepare_boot_cache="$(prepare_grub_to_access_device ${GRUB_DEVICE_BOOT} | sed -e "s/^/\t/")"
if test -e /boot/memtest86+.bin ; then MEMTESTPATH=$( make_system_path_relative_to_its_root "/boot/memtest86+.bin" ) echo "Found memtest86+ image: $MEMTESTPATH" >&2 cat << EOF menuentry "Memory test (memtest86+)" { EOF printf '%s\n' "${prepare_boot_cache}" cat << EOF $LX $MEMTESTPATH } menuentry "Memory test (memtest86+, serial console 115200)" { EOF printf '%s\n' "${prepare_boot_cache}" cat << EOF $LX $MEMTESTPATH console=ttyS0,115200n8 } EOF fi
#if test -e /boot/memtest86+_multiboot.bin ; then
MEMTESTPATH=$( make_system_path_relative_to_its_root "/boot/memtest86+_multiboot.bin" )
echo "Found memtest86+ multiboot image: $MEMTESTPATH" >&2
cat << EOF
#menuentry "Memory test (memtest86+, experimental multiboot)" { #EOF
cat << EOF
multiboot $MEMTESTPATH
#} #menuentry "Memory test (memtest86+, serial console 115200, experimental multiboot)" { #EOF
cat << EOF
multiboot $MEMTESTPATH console=ttyS0,115200n8
#} #EOF #fi
Make sure to run the chmod +x command on it afterwards.
I'd be a bit concerned that it's missing though - do you have everything else in grub.d ?
$ ls /etc/grub.d/
00_header 10_linux.bak 20_memtest86+ 41_custom 05_debian_theme 10_linux.dpkg-old 30_os-prober README 10_linux 20_linux_xen 40_custom
Pablo Bianchi
  • 17,371
23
apt install memtest86+
This will automatically reconfigure grub and add the entry to the boot menu.
If you get the error memtest86+ is already the newest version then use sudo apt-get install --reinstall memtest86+
If all else fails you can get a bootable ISO that you can burn to a CD and boot from. Of course if you are booting UEFI you should be here instead.
Michael F
  • 662
16
I had the same issue, and due to the fact that I have EFI on my laptop the memtest86+ version 4.x shipped by ubuntu won't work, since EFI is only supported by version 5 and newer.
The latest versions are non-GPL and must be downloaded manually from the memtest website(they have ISO and USB images), but at least they are free of charge.
I didn't managed to make this work in 2 days, then I checked Synaptic for grub packages... Seems to be, that the absence of package grub-imageboot are the root of the problem.
sudo apt-get install grub-imageboot
Braiam
  • 69,112
PLaci
  • 61
This what I did to add the now latest (non-free) memtest86+ to the grub boot menu for UEFI booting. Current memtest version is 8.2.
Tools needed: Disk Image Mounter and grub-customizer, the latter is only for convenience :)
Files: memtest binary (see below).
  1. Download the memtest binary from: https://www.memtest86.com/download.htm The 'Image for creating bootable USB Drive on a Windows/Linux/Mac system' is fine.
  2. Extract the IMG file (memtest86-usb.img)
  3. Open the img file with disk image mounter (right mouse button on Ubuntu)
  4. From the mounted image extract /EFI/BOOT/BOOTX64.efi
  5. Make memtest86 boot directory:
    sudo mkdir /boot/efi/EFI/memtest86
  6. Copy the BOOTX64.efi to your new folder on the boot partition (eg /boot/efi/EFI/memtest86)
  7. Open grub-customizer
  8. Add menu item, give it a name, choose type: other
  9. Add the following boot sequence (assuming you boot from hd0):
    insmod part_gpt
    insmod fat
    set root='hd0,gpt2'
    if [ x$feature_platform_search_hint = xy ]; then
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2  1A22-970F
    else
      search --no-floppy --fs-uuid --set=root 1A22-970F
    fi
    chainloader /EFI/memtest86/BOOTX64.efi
  10. Save and quit grub-customizer
  11. reboot and enjoy Memtest86
Pablo Bianchi
  • 17,371
Vic
  • 391
See also this answer on the Unix StackExchange. In short, the Linux Kernel has a simple memory test built in.
Do grep CONFIG_MEMTEST "/boot/config-$(uname -r)" to determine if it's enabled or not (it'll be commented out if it's not enabled).
Then, edit /etc/default/grub and add memtest to GRUB_CMDLINE_LINUX_DEFAULT, run sudo update-grub, and then reboot.
Once it's finished booting up (it'll take longer than normal given it has to also run the memory test), check /var/log/kern.log for the result of the test.
