The machine keeps freezing, mainly when using the Chromium or the OpenOffice. But it is random. When it freezes, the terminal is not accessible neither the tty terminal using CTRL+ALT+ Fx. The machine simply stops responding. I checked some of the suggestions mentioned here: Tools to diagnose Ubuntu problems but i did not found any problems. I formated the hard disk and install the 16.04 64 bits ubuntu and all the updates but the problem keeps occuring. The user is feed up and ands to return to windows but i want to give a try but this kind of problems does not happens in any of my computers. Can anyone help me to find the problems for this mistery? Thank you.
I had this issue with my two HP pc: pavillion and Elitebook 8450P the issue was due to the graphic card driver ... On HP Elitebook 8450P shifting into the open source instead of Nvidia driver solved the issue On both cases I used other drivers option to change driver and solve the issue
You may consider this option as one possible solution
- 1
Are you sure it isn't a hardware problem? Your syslogs aren't turning up any errors(did you check them all?), that makes me think it might not be a OS problem.
You can check your memory with memtest86, https://help.ubuntu.com/16.04/ubuntu-help/disk-check.html for your hard drive.(or use UBCD or something like it to test your system).
You could test to see if the problem occurs in windows. it will at least help you exclude some things.
- 541
I found that upgrading to the 4.6.5 kernel (http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.6.5/) helps a lot - no freezing at this level.
At 4.7.x and later releases, there are some improvements (battery status indicator works) but the freezing returns. Also try the most recent kernel releases as Cherry Trail support seems to be improving little by little.
- 11
