97
I tried to install Ubuntu 18.10 on my XPS 15 9570 earlier. Everything was working fine until I got to the partition selection part of the installation. That's when the installer crashed and I had to shut down my machine. I think it's because I had my SATA configuration set to RAID ON instead of AHCI, which is now fixed.
Now when I try to run the installer from my bootable USB I get the following error
Failed to open \EFI\BOOT\mmx64.efi - Not Found
Failed to load image \EFI\BOOT\mmx64.efi: Not Found
Failed to start MokManager: Not Fond
Something has gone seriously wrong: import_mok_state() failed
Hoping someone might have some idea as to what is going on
Ctrl-C
  • 149
rykeeboy
  • 993
11 Answers11
98
I booted an Ubuntu Live USB stick, went into my hard disk drive's /boot/efi folder and renamed the file grubx64.efi to mmx64.efi
Reboot the machine and it should work.
Fabby
  • 35,017
Joe Meagher
  • 1,012
47
The problem was that in the bootable USB the file mmx64.efi didn't exist, so the workaround was to copy the file grubx64.efi under the name mmx64.efi (so the USB Drive folder /EFI/BOOT now contains three files: BOOTx64.EFI, grubx64.efi and mmx64.efi). Then, reboot and the installation should work.
I created the USB bootable drive from Windows 10 with Rufus.
The copying can be done using any file editor on the same or another computer, if the default settings have been used in Rufus for the USB drive.
26
The answers here all suggest modifying the file system on the live USB, which isn't really possible without rebuilding the entire ISO image as far as I have understood.
I think the reason my problem, and the OP's problem, occurred was that we checked the box for installing third-party software in the installer, and subsequently checked the box for managing secure boot through MOK as required, but were then unable to finish the installation and left the computer in a state where it was expecting to boot the MOK manager on the next boot with a path that exists in the Ubuntu system, but not on the Live USB.
To solve this I did a strange work around. I followed the instructions for installing Ubuntu through Wubi as provided here, and then, after restarting my computer, Wubi managed to launch the MOK manager and although I didn't perform any MOK management it seems like this stopped the computer from expecting to find a MOK manager on startup, and when I tried to boot from USB afterwards it suddenly worked. Afterwards I just deleted the Wubi install and all the Wubi files and installed Ubuntu the normal way using the Live USB.
I could be wrong about my assumptions in this answer, but after trying several USBs and many different Ubuntu ISO images, this was what finally did the trick.
Note: What I described in this answer requires that you have Windows installed, which you may not. If you don't, you might be able to solve it in a similar way by booting a system that has GRUB and the MOK manager on it.
tjespe
  • 1,368
I faced the same problem with the same error message when installing Ubuntu 18.04.2 LTS on my Acer Aspire V 17 Nitro Black Edition. The proper solution for me was to turn on secure boot again and to add the \EFI\BOOT\grubx64.efi (located on the Ubuntu installation USB medium) to the trusted .efi list in my BIOS (F2) and turned the secure boot off again. Afterwards I rebooted and called the the boot manager via F12 there I was able to select the trusted efi file. This invoked grub and I just needed to select install Ubuntu to start the installation.
Westranger
  • 160
Secure Boot with third party drivers checked/enabled during Install requires registering new MOK into UEFI at reboot. Ubuntu installer does this by registering some Mok* EFI variables before it has actually finished creating the EFI System Partition for your new Ubuntu installation. If the Installer is interrupted before it is finished, we need to remove two Mok* EFI variables:
Variable NV+RT+BS '605DAB50-E046-4300-ABB6-3DD810DD8B23:MokAuth' DataSize = 0xAC
Variable NV+RT+BS '605DAB50-E046-4300-ABB6-3DD810DD8B23:MokNew' DataSize = 0x3C5
Run the following two commands from the UEFI (Internal) Shell:
dmpstore -d -all MokAuth
dmpstore -d -all MokNew
Now when you reboot with your Ubuntu installation media, you should no longer get the "Failed to open \EFI\BOOT\mmx64.efi - Not Found" error.
If your Secure Boot signed Internal Shell does not have the dmpstore command (or you do not have an Internal Shell option), you will have to temporarily disable Secure Boot and use a different Shell (e.g., Copy https://github.com/tianocore/edk2/blob/UDK2018/ShellBinPkg/UefiShell/X64/Shell.efi to a USB_flash_drive at /EFI/Boot/bootx64.efi and boot it).
Update: For a Secure Boot enabled solution: boot https://clonezilla.org/downloads/download.php?branch=alternative "alternative amd64" with Secure Boot enabled. Enter_shell command line prompt. cmd Enter command line prompt. Run:
sudo chattr -i /sys/firmware/efi/efivars/Mok{Auth,New}
sudo rm /sys/firmware/efi/efivars/Mok{Auth,New}
Ref: https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/1798171/comments/51
rcpa0
  • 604
This happens because windows gets a chance to run first, runs its updates and turns on secure boot in the bios. You need to go into bios and turn it off. During ubuntu installation it will ask to turn it on if you install 3rd party drivers.
Windows just Hellen Keller's your BIOS and lets you figure out what it messed up.
Alex
  • 31
I had the same problem. Creating an UEFI-only bootable USB did the trick for me. Here're the instructions.
More information about the UEFI bootable on Ubuntu.
Pablo Bianchi
  • 17,371
Hamed
  • 93
I ended up installing JackHack96's Ubuntu 18.04 respin for the XPS 15 and then upgrading to 18.10
rykeeboy
  • 993
For me, the following worked.
  1. Keep the secure boot on
  2. Go to BIOS by pressing F2 during boot, then go to Boot using arrow keys. Click on UEFI Hard Disk Drive BBS Priorities
                 Aptio Setup Utility - Copyright (C) 2014 ...
      Main  Advanced  Chipset  Feature | Boot | Security ...
      Boot Configuration
      Bootup NumLock State  [On]
      Quiet Boot            [Enabled]
      Set Boot Priority
      Boot Option #1        [USB Key]
      Boot Option #2        [CD/DVD]
      Boot Option #3        [Hard Disk:ubuntu]
      Boot Option #4        [USB CD/DVD]
      Boot Option #5        [USB Hard Disk]
      Boot Option #6        [Network]
                 Version 2.15.1236. Copyright (C) 2014 ...
    Transcribed from: BIOS screenshot 1
  3. Then, you get to this screen:
                                     | Boot |
      Boot Option #1        [ubuntu]
      Boot Option #2        [UEFI OS (P0: SAMSUN...]
      Boot Option #3        [ubuntu (P0: SAMSUNG...]
    Transcribed from: BIOS screenshot 2
    Here make sure that Boot Option #1 is selected as ubuntu
Note: Not sure if this will create issues if you have dual boot with Windows. In my case, I only have Ubuntu! Also, as suggested by Fransisco, I copied grub64.efi to mmx64.efi to make it boot.
pawanlri
I used PowerISO for Linux to modify the ISO and copy grubx64.efi to mmx64.efi inside \EFI\BOOT\ directory.
Mitar
  • 2,062
i solved the problem by following this page: https://www.pcwelt.de/ratgeber/So-klappt-der-Multiboot-mit-Windows-Linux-Doppel-OS-9666313.html
Ok, its written in german, so i will translate the part, which solved my problem: in the boot menue, and there the boot options, you have to search for somthing like "CSM"; "Launch CSM"; "UEFI and Legacy". This option has to be enabled. The boot mode has to be on "Auto".
After this, i could boot from ubuntu-cd. but only overwrite the preinstalled windows 10...which wasnt a real lose.
Tob
