all. I'm trying to fix my system so I can install the nvidia drivers but it seems to get stuck for some reason. I have tried manually removing the downloaded files from
/var/cache/apt/archives/libnvidia-gl-390_390.48-0ubuntu3_i386.deb
/var/cache/apt/archives/libnvidia-gl-390_390.48-0ubuntu3_amd64.deb
... in order to let them download again but to no avail. Have anyone tried installing those drivers on 18.04 lately?
~$ sudo apt --fix-broken install
[sudo] password for jarl:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
lib32gcc1 libc6-i386
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-gl-390 libnvidia-gl-390:i386
The following NEW packages will be installed
0 to upgrade, 2 to newly install, 0 to remove and 4 not to upgrade.
3 not fully installed or removed.
Need to get 0 B/29,1 MB of archives.
After this operation, 147 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 214344 files and directories currently installed.)
Preparing to unpack .../libnvidia-gl-390_390.48-0ubuntu3_i386.deb ...
diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340
dpkg-divert: error: mismatch on package
when removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 by libnvidia-gl-390'
found 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-390_390.48-0ubuntu3_i386.deb (--unpack):
new libnvidia-gl-390:i386 package pre-installation script subprocess returned error exit status 2
Preparing to unpack .../libnvidia-gl-390_390.48-0ubuntu3_amd64.deb ...
diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340
when removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 by libnvidia-gl-390'
found 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-390_390.48-0ubuntu3_amd64.deb (--unpack):
new libnvidia-gl-390:amd64 package pre-installation script subprocess returned error exit status 2
