I wanted to install Nvidia drivers in ubuntu 18.04 but
In terminal
$ sudo ubuntu-drivers autoinstall
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
nvidia-340
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
9 not fully installed or removed.
Need to get 0 B/51.9 MB of archives.
After this operation, 274 MB of additional disk space will be used.
(Reading database ... 277981 files and directories currently
installed.)
Preparing to unpack .../nvidia-340_340.107-0ubuntu0.18.04.2_amd64.deb
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to
/usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to
/usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg-divert: error: rename involves overwriting '/usr/lib/i386-linux-
gnu/libGL.so.1.distrib' with
different file '/usr/lib/i386-linux-gnu/libGL.so.1', not allowed
dpkg: error processing archive /var/cache/apt/archives/nvidia-
340_340.107-0ubuntu0.18.04.2_amd64.deb (--unpack):
new nvidia-340 package pre-installation script subprocess returned
error exit status 2
/var/cache/apt/archives/nvidia-340_340.107-0ubuntu0.18.04.2_amd64.deb
it never installed I tried many commend but it won't fix
UPDATE
I have followed Installing nvidia drivers on 18.04 this link but still the result same
The following additional packages will be installed:
dkms lib32gcc1 libc6-i386 libcuda1-340 libxnvctrl0 nvidia-opencl-icd-
340
nvidia-settings pkg-config screen-resolution-extra
Suggested packages:
menu
dkms lib32gcc1 libc6-i386 libcuda1-340 libxnvctrl0 nvidia-340
nvidia-opencl-icd-340 nvidia-settings pkg-config screen-resolution-
extra
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/73.3 MB of archives.
After this operation, 346 MB of additional disk space will be used.
Selecting previously unselected package dkms.
(Reading database ... 277766 files and directories currently
installed.)
Preparing to unpack .../0-dkms_2.3-3ubuntu9.2_all.deb ...
Unpacking dkms (2.3-3ubuntu9.2) ...
Selecting previously unselected package libc6-i386.
Preparing to unpack .../1-libc6-i386_2.27-3ubuntu1_amd64.deb ...
Unpacking libc6-i386 (2.27-3ubuntu1) ...
Replaced by files in installed package libc6:i386 (2.27-3ubuntu1) ...
Selecting previously unselected package libcuda1-340.
Preparing to unpack .../2-libcuda1-340_340.107-
0ubuntu0.18.04.2_amd64.deb ...
Unpacking libcuda1-340 (340.107-0ubuntu0.18.04.2) ...
Selecting previously unselected package libxnvctrl0:amd64.
Preparing to unpack .../3-libxnvctrl0_418.56-
0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libxnvctrl0:amd64 (418.56-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package lib32gcc1.
Preparing to unpack .../4-lib32gcc1_1%3a8.3.0-6ubuntu1~18.04_amd64.deb
Unpacking lib32gcc1 (1:8.3.0-6ubuntu1~18.04) ...
Preparing to unpack .../5-nvidia-340_340.107-
dpkg-divert: error: rename involves overwriting '/usr/lib/x86_64-
linux-
different file '/usr/lib/x86_64-linux-gnu/libGL.so.1', not allowed
dpkg: error processing archive /tmp/apt-dpkg-install-61TLve/5-nvidia-
error
exit status 2
Selecting previously unselected package nvidia-opencl-icd-340.
Preparing to unpack .../6-nvidia-opencl-icd-340_340.107-
Unpacking nvidia-opencl-icd-340 (340.107-0ubuntu0.18.04.2) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../7-pkg-config_0.29.1-0ubuntu2_amd64.deb ...
Unpacking pkg-config (0.29.1-0ubuntu2) ...
Selecting previously unselected package screen-resolution-extra.
Preparing to unpack .../8-screen-resolution-extra_0.17.3_all.deb ...
Unpacking screen-resolution-extra (0.17.3) ...
Selecting previously unselected package nvidia-settings.
Preparing to unpack .../9-nvidia-settings_418.56-
Unpacking nvidia-settings (418.56-0ubuntu0~gpu18.04.1) ...
/tmp/apt-dpkg-install-61TLve/5-nvidia-340_340.107-
