Got Ubuntu 16.04, bought a MSI GTX 1060 Gaming X, connected it to PCI, lights on, but actually I dont know how to install and use it.
Last time I installed the Cuda package, I ended up in a login loop and had to reinstall Ubuntu.
The CD that came with the GPU seems to contain only Win-Drivers. Has anyone the same or pretty similar GPU and can tell me how to install or where is a tutorial for this?
Thank you.
PortWein
  • 175
  1. Add the Official Graphic Cards PPA
     sudo add-apt-repository ppa:graphics-drivers/ppa
     sudo apt-get update
  2. Check which Nvidia Driver Version is the latest: Go to https://www.geforce.com/drivers and pick your GPU, check which one is the non-beta. Today the version is 390.
  3. Leave the X server: Press Ctrl+Alt+F1 it should give you a black screen asking you to log in. After logging in, shut down the x-server with
     sudo service lightdm stop
  4. Install your Nvidia Driver
     sudo apt-get install nvidia-driver-390
  5. Reboot your PC
     sudo reboot
Tashows
  • 103
Seraf
  • 311
After I ran
sudo apt-get install nvidia-390
before
in the UNIX-terminal, I ended up in some kind of messy loop. So I purged nvidia-390 with
apt-get remove --purge nvidia-390
Then I opened tty1 (Ctrl+Alt+F1), ran the 2 commands again and rebooted.
Any more adjustments to make?
PortWein
  • 175
