I'm having trouble downgrading my nvidia drivers from 396 to 390. If I purge all of the nvidia drivers, then do sudo apt install nvidia-driver-390 it still installs the 396 version. Is there any way to force it to install the older version?
I've tried sudo apt install nvidia-driver-390=390.59-0ubuntu0~gpu18.04.1, but that gives me the following error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 nvidia-driver-390 : Depends: libnvidia-gl-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: nvidia-dkms-390 (= 390.59-0ubuntu0~gpu18.04.1)
                     Depends: nvidia-kernel-source-390 (= 390.59-0ubuntu0~gpu18.04.1)
                     Depends: libnvidia-compute-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: nvidia-compute-utils-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: libnvidia-decode-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: libnvidia-encode-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: nvidia-utils-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: xserver-xorg-video-nvidia-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: libnvidia-cfg1-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: libnvidia-ifr1-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Depends: libnvidia-fbc1-390 (= 390.59-0ubuntu0~gpu18.04.1) but 396.24-0ubuntu1~pop1 is to be installed
                     Recommends: nvidia-settings but it is not going to be installed
                     Recommends: nvidia-prime (>= 0.8)
                     Recommends: libnvidia-compute-390:i386 (= 390.59-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-decode-390:i386 (= 390.59-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-encode-390:i386 (= 390.59-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-ifr1-390:i386 (= 390.59-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-fbc1-390:i386 (= 390.59-0ubuntu0~gpu18.04.1)
                     Recommends: libnvidia-gl-390:i386 (= 390.59-0ubuntu0~gpu18.04.1)
Is there some way of telling it to use the older versions of the dependencies?
It's becoming very frustrating as the 396 drivers appear to be causing problems with any games I have installed, whereas the 390 worked fine, but I can't seem to rollback and no option for the older version appear in the Software/Updates app either.
Thanks
Update:
As requested, here's the output of apt policy nvidia-390 following installation via PPA:
nvidia-390:
  Installed: 390.67-0ubuntu0~gpu18.04.1
  Candidate: 390.67-0ubuntu0~gpu18.04.1
  Version table:
 *** 390.67-0ubuntu0~gpu18.04.1 500
        500 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main amd64 Packages
        100 /var/lib/dpkg/status
Also, here's the output from the actual installation (sudo apt install nvidia-390):
The following additional packages will be installed:
  dkms libnvidia-cfg1-396 libnvidia-common-396 libnvidia-compute-396
  libnvidia-compute-396:i386 libnvidia-decode-396 libnvidia-decode-396:i386
  libnvidia-encode-396 libnvidia-encode-396:i386 libnvidia-fbc1-396
  libnvidia-fbc1-396:i386 libnvidia-gl-396 libnvidia-gl-396:i386
  libnvidia-ifr1-396 libnvidia-ifr1-396:i386 libxnvctrl0
  nvidia-compute-utils-396 nvidia-dkms-396 nvidia-driver-390 nvidia-driver-396
  nvidia-kernel-common-396 nvidia-kernel-source-396 nvidia-prime
  nvidia-settings nvidia-utils-396 screen-resolution-extra
  xserver-xorg-video-nvidia-396
Suggested packages:
  menu
The following NEW packages will be installed
  libnvidia-ifr1-396 libnvidia-ifr1-396:i386 libxnvctrl0 nvidia-390
0 to upgrade, 28 to newly install, 0 to remove and 0 not to upgrade.
Need to get 16.1 kB/88.7 MB of archives.
After this operation, 365 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://ppa.launchpad.net/system76/pop/ubuntu bionic/main amd64 nvidia-driver-390 amd64 396.24-0ubuntu1~pop1 [8,072 B]
Get:2 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main amd64 nvidia-390 amd64 390.67-0ubuntu0~gpu18.04.1 [8,044 B]
Fetched 16.1 kB in 0s (85.5 kB/s)
Selecting previously unselected package dkms.
(Reading database ... 287858 files and directories currently installed.)
Preparing to unpack .../00-dkms_2.3-3ubuntu9.1_all.deb ...
Unpacking dkms (2.3-3ubuntu9.1) ...
Selecting previously unselected package libnvidia-cfg1-396:amd64.
Preparing to unpack .../01-libnvidia-cfg1-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-cfg1-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-common-396.
Preparing to unpack .../02-libnvidia-common-396_396.24.02-0ubuntu0~gpu18.04.1_all.deb ...
Unpacking libnvidia-common-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-compute-396:i386.
Preparing to unpack .../03-libnvidia-compute-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
Unpacking libnvidia-compute-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-compute-396:amd64.
Preparing to unpack .../04-libnvidia-compute-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-compute-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-decode-396:i386.
Preparing to unpack .../05-libnvidia-decode-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
Unpacking libnvidia-decode-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-decode-396:amd64.
Preparing to unpack .../06-libnvidia-decode-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-decode-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-encode-396:amd64.
Preparing to unpack .../07-libnvidia-encode-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-encode-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-encode-396:i386.
Preparing to unpack .../08-libnvidia-encode-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
Unpacking libnvidia-encode-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-fbc1-396:i386.
Preparing to unpack .../09-libnvidia-fbc1-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
Unpacking libnvidia-fbc1-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-fbc1-396:amd64.
Preparing to unpack .../10-libnvidia-fbc1-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-fbc1-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-gl-396:i386.
Preparing to unpack .../11-libnvidia-gl-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
dpkg-query: no packages found matching libnvidia-gl-390
Unpacking libnvidia-gl-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-gl-396:amd64.
Preparing to unpack .../12-libnvidia-gl-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-gl-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-ifr1-396:i386.
Preparing to unpack .../13-libnvidia-ifr1-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
Unpacking libnvidia-ifr1-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libnvidia-ifr1-396:amd64.
Preparing to unpack .../14-libnvidia-ifr1-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-ifr1-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package libxnvctrl0:amd64.
Preparing to unpack .../15-libxnvctrl0_396.24-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libxnvctrl0:amd64 (396.24-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-kernel-source-396.
Preparing to unpack .../16-nvidia-kernel-source-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-kernel-source-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-kernel-common-396.
Preparing to unpack .../17-nvidia-kernel-common-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-kernel-common-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-dkms-396.
Preparing to unpack .../18-nvidia-dkms-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-dkms-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-compute-utils-396.
Preparing to unpack .../19-nvidia-compute-utils-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-compute-utils-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-utils-396.
Preparing to unpack .../20-nvidia-utils-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-utils-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package xserver-xorg-video-nvidia-396.
Preparing to unpack .../21-xserver-xorg-video-nvidia-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking xserver-xorg-video-nvidia-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-driver-396.
Preparing to unpack .../22-nvidia-driver-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-driver-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-driver-390.
Preparing to unpack .../23-nvidia-driver-390_396.24-0ubuntu1~pop1_amd64.deb ...
Unpacking nvidia-driver-390 (396.24-0ubuntu1~pop1) ...
Selecting previously unselected package nvidia-390.
Preparing to unpack .../24-nvidia-390_390.67-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-390 (390.67-0ubuntu0~gpu18.04.1) ...
Selecting previously unselected package nvidia-prime.
Preparing to unpack .../25-nvidia-prime_0.8.8_all.deb ...
Unpacking nvidia-prime (0.8.8) ...
Selecting previously unselected package screen-resolution-extra.
Preparing to unpack .../26-screen-resolution-extra_0.17.3_all.deb ...
Unpacking screen-resolution-extra (0.17.3) ...
Selecting previously unselected package nvidia-settings.
Preparing to unpack .../27-nvidia-settings_396.24-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking nvidia-settings (396.24-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-fbc1-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-fbc1-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-prime (0.8.8) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Setting up libnvidia-cfg1-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3) ...
Setting up nvidia-kernel-common-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
update-initramfs: deferring update (trigger activated)
Created symlink /etc/systemd/system/multi-user.target.wants/nvidia-fallback.service → /lib/systemd/system/nvidia-fallback.service.
Setting up xserver-xorg-video-nvidia-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-kernel-source-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-common-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up dkms (2.3-3ubuntu9.1) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Setting up screen-resolution-extra (0.17.3) ...
Setting up libnvidia-compute-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-compute-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-dkms-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
Loading new nvidia-396.24.02 DKMS files...
Building for 4.15.0-23-generic
Building for architecture x86_64
Building initial module for 4.15.0-23-generic
Secure Boot not enabled on this system.
Done.
nvidia:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.15.0-23-generic/updates/dkms/
nvidia-modeset.ko:
 - Original module
 - Installation
nvidia-drm.ko:
 - Original module
 - Installation
nvidia-uvm.ko:
 - Original module
 - Installation
depmod...
DKMS: install completed.
Processing triggers for man-db (2.8.3-2) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1) ...
Processing triggers for dbus (1.12.2-1ubuntu1) ...
Setting up libxnvctrl0:amd64 (396.24-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-decode-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-decode-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-utils-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-settings (396.24-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-gl-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-gl-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-compute-utils-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 103) ...
Adding new group `nvidia-persistenced' (GID 105) ...
Adding new user `nvidia-persistenced' (UID 103) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up libnvidia-ifr1-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-ifr1-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-encode-396:amd64 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up libnvidia-encode-396:i386 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-driver-396 (396.24.02-0ubuntu0~gpu18.04.1) ...
Setting up nvidia-driver-390 (396.24-0ubuntu1~pop1) ...
Setting up nvidia-390 (390.67-0ubuntu0~gpu18.04.1) ...
Processing triggers for initramfs-tools (0.130ubuntu3pop2) ...
update-initramfs: Generating /boot/initrd.img-4.15.0-23-generic
and finally, the output from glxinfo | egrep "version":
server glx version string: 1.4
client glx version string: 1.4
GLX version: 1.4
OpenGL core profile version string: 4.6.0 NVIDIA 396.24.02
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL version string: 4.6.0 NVIDIA 396.24.02
OpenGL shading language version string: 4.60 NVIDIA
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 396.24.02
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
    GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
You can't install the 390 version of Nvidia drivers from Ubuntu repos, because the nvidia-390 package pulls the 396 drivers.
But the good news is that you can install the 390 driver from ppa:graphics-drivers/ppa
Run
sudo apt purge 'nvidia.*'
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
Pilot6
  • 92,041
