I have Dell model XPS 15 and just installed a fresh Ubuntu 22.04.1 LTS. I have lots of problems installing it at first but after some time I was successful. I also tried to install the "nvidia-drivers-515" drivers. I had some problems with this as well but finally got it instlled.
Ubuntu still seems to be using the integrated card instead of the Nvidia.
This is some output.
➜ ~ lspci -nn | grep -E 'VGA|Display'
00:02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-P Integrated Graphics Controller [8086:46a6] (rev 0c)
The system recognize both cards but integrated one is being used.
➜ ~ sudo lshw -c video
*-display
description: 3D controller
product: GA107M [GeForce RTX 3050 Ti Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=3456x2160 visual=truecolor xres=3456 yres=2160
resources: iomemory:600-5ff iomemory:610-60f irq:189 memory:bb000000-bbffffff memory:6000000000-60ffffffff memory:6100000000-6101ffffff ioport:3000(size=128)
*-display
description: VGA compatible controller
product: Alder Lake-P Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 0c
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=3456,6480
resources: iomemory:610-60f iomemory:400-3ff irq:188 memory:6186000000-6186ffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
From the following output Nvidia seams to be sleeping or im missing something?
➜ ~ nvidia-smi
Mon Oct 10 23:23:33 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 46C P3 N/A / N/A | 4MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 2372 G /usr/lib/xorg/Xorg 4MiB |
Why both cards are active? How can i make sure that I'm using the Nvidia and the drivers are working properly?
Update: The output from the command from comments
➜ ~ glxinfo | grep OpenGL
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) Graphics (ADL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 22.0.5
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 22.0.5
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.0.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
