I've been trying to make my linux detect GTX 1650 so I'd make my dual monitors work but I couldn't. I tried the following:
- using lightdm instead of gdm3:
dpkg-recongigure lightdm installing several nvidia drivers (nvidia-drivers-390,nvidia-drivers-418,435,430), I'd restart after each installation to check if it works, but that also didn't work
Turning off Secure Boot and playing with all settings in BIOS regarding GPU but to no avail
Here are my system information: dell optiplex 9010, Ventus GTX 1650 4GB, i7 3770k, 16GB ram
Here some output that may be useful:
uname -a
Linux system 5.0.0-37-generic #40~18.04.1-Ubuntu SMP Thu Nov 14 12:06:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
dpkg -l | grep nvidia
ii libnvidia-cfg1-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-390 390.116-0ubuntu0.18.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-common-430 430.50-0ubuntu0.18.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-common-435 435.21-0ubuntu0.18.04.2 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-390:amd64 390.116-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-390:i386 390.116-0ubuntu0.18.04.1 i386 NVIDIA libcompute package
ii libnvidia-compute-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-430:i386 430.64-0ubuntu0~gpu18.04.1 i386 NVIDIA libcompute package
rc libnvidia-compute-435:amd64 435.21-0ubuntu0.18.04.2 amd64 NVIDIA libcompute package
ii libnvidia-decode-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-430:i386 430.64-0ubuntu0~gpu18.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-430:i386 430.64-0ubuntu0~gpu18.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-fbc1-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-430:i386 430.64-0ubuntu0~gpu18.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-430:i386 430.64-0ubuntu0~gpu18.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-430:amd64 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-430:i386 430.64-0ubuntu0~gpu18.04.1 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii nvidia-compute-utils-430 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-430 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-430 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-430 430.64-0ubuntu0~gpu18.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-430 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.8.2 all Tools to enable NVIDIA's Prime
ii nvidia-settings 418.56-0ubuntu0~gpu18.04.1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-430 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-430 430.64-0ubuntu0~gpu18.04.1 amd64 NVIDIA binary Xorg driver
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a4)
00:1f.0 ISA bridge: Intel Corporation Q77 Express Chipset LPC Controller (rev 04)
00:1f.2 RAID bus controller: Intel Corporation SATA Controller [RAID mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f82 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
sudo lshw -c display
*-display UNCLAIMED
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
