If you want to help develop and debug the latest and greatest Ubuntu
- I suggest that you keep the testing separate from your production system, your main operating system.
Other people are actually using the developing release as their production system, which is good for testing, but it can be a bumpy ride. Some new program versions may not cooperate well with some other program, so that some things stop working (usually for a short time). Anyway, you should expect some 'hiccups' in the developing version.
If your computer is powerful enough, you can install VirtualBox and run the developing release in a virtual machine. The virtual machine can boot directly from an iso file in the host machine, so you need no USB/DVD drive.
This method is safe, the testing will not affect the host operating system.
Otherwise you can install the developing release alongside your production system, 'dual boot or multi boot'.
This is more risky, and it will be 'even more important' to backup your production system frequently.
This is also a more valuable test (compared to running in VirtualBox), because it is testing Ubuntu with the actual hardware in your computer.
You find the daily iso files via the ISO testing tracker. The zsync method can be recommended. It downloads only the differences compared to your previous version of the daily iso file, and there is a built-in checksum test.
You can use a line in a shellscript for each iso file that you are testing, for example
zsync http://cdimage.ubuntu.com/daily-live/current/bionic-desktop-amd64.iso.zsync
Please help by reporting bugs at Launchpad and the ISO testing tracker
You can also discuss the developing version at this Ubuntu Forum
There {are/will be} 5 or more point releases of the LTS versions. The 1st point release has the same kernel as the original version. The 2nd - 5th point releases have updated hardware enablement stacks and kernels corresponding to the regular releases and finally xx.04.5 corresponding to the next LTS release. See this link,
https://www.ubuntu.com/info/release-end-of-life
Until the 5th point release is official, there are daily iso files to be tested for the LTS versions.
Alongside testing the iso files: Running live and installing, it is also valuable to test
running and keeping the installed system up to date
release-upgrading from the previous version and previous LTS version.
Alongside testing standard Ubuntu and Ubuntu Server, it is important to test the Ubuntu family flavours. The community teams are often small, and a new active tester can make a big difference for Kubuntu, Lubuntu, Ubuntu Budgie, Ubuntu Kylin, Ubuntu MATE, Ubuntu Studio, Xubuntu.
So please select what you find interesting and important. Your help will be appreciated :-)
If you want a smooth ride
Wait until the next version is released. Two new versions are released every year, in April, xx.04, and October, xx.10. Versions released in April during even years have long time support, LTS, and are recommended, unless you have new hardware, and need the newest hardware drivers.
As a matter of fact, if you want a really smooth ride, you should stay with versions with long time support, LTS, and wait until July or August, when the first point release is available (2022: Ubuntu 22.04.1 LTS).
My experience from previous versions with long time support, LTS, is that the first point release is debugged and polished.
I think 22.04 LTS {will be/is} a good release, but bugs will be found, when it is used by many more people, not only the testers, and in many more computers with various hardware components. There will be time to squash these bugs until the first point release.
