43
After the upgrade I noticed that I don't have internet access. The wired network and the wifi settings looked good, but it didn't work. After the login the system always switched itself into airplane mode. I tethered the network via USB and Bluetooth by my mobile but they also didn't work.
10 Answers10
41
Update 2: the bugreport was refused because I couldn't reproduce it on the already upgraded system and couldn't provide data for the developers.
Update 1: I reported the bug on launchpad. You can subscribe if you are involved: https://bugs.launchpad.net/ubuntu/+bug/1816530
the ORIGIN of the solution
if the /etc/resolv.conf is empty but you can ping 8.8.8.8
$ echo "nameserver 8.8.8.8" | sudo tee /etc/resolv.conf > /dev/null
if the /etc/resolvconf/resolv.conf.d/head is empty then you have to repeat the command above after every restart except you do this:
$ echo "nameserver 8.8.8.8" | sudo tee -a /etc/resolvconf/resolv.conf.d/head > /dev/null
then you have to restart the resolvconf and the networking
$ sudo systemctl enable resolvconf
$ sudo systemctl start resolvconf
$ sudo /etc/init.d/networking restart
11
I agree with some other folks here that the selected answer is probably not the best way to fix the issue:
When a file has a comment at its beginning that says
"DO NOT EDIT THIS FILE"
then there is probably a very good reason to, well, ... not edit that file! ;-)
And here is why, as well as a suggestion for a better (IMHO) solution:
a. the file /etc/resolv.conf, that you modified, will be overwritten at boot time, so your modification won't 'stick'.
b. the ip address (127.0.0.53) that was originally in there (before you modified it) is actually the address of a DNS stub resolver. It's there! You can ping it! it's running locally on your machine. What is a stub resolver? It takes your DNS queries and looks in its cache for a resolution! If it can't find any, it will reach out to a real DNS server (and then cache the result). So, if you overwrite the address of the stub resolver, you're going to miss out on this important caching function of the stub resolver!
The problem with this new resolver method in Ubuntu 18.04 is that the 'real' DNS server address was never set. So, if the stub resolver doesn't find your requested domain in its cache, it doesn't know what DNS server to query. (Hence your domain name based internet accesses no longer working). So all you have to do is configure the 'real' DNS server that this stub resolver must use. And you do this by editing (sudo!) /etc/systemd/resolved.conf
Simply add something like
DNS=8.8.8.8
to that file.
Then restart the network, or rather, reboot, so you can verify that you now have a solution that is persistent across reboots.
(What I haven't figured out yet, is why DHCP doesn't properly set the correct DNS server!)
Accepted answer did solve my problem. However, as everyone else stated, that is only until you reboot which I do daily with my machine. Typing 5 to 6 lines in the terminal every time I start the system up isn't something I would find amusing.
After digging on the internet I found a solution to permanently solve the problem. I rebooted 3 times afterward just to be sure, internet connection is there and I don't have to do anything.
Solution:
Start the terminal and type:
$ ifconfig
Now you gotta figure out which is your Ethernet interface. Mine is listed as eth1. Next type:
$sudo gedit /etc/network/interfaces
My file only had:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
Now what you need to do is to add the following lines afterwards:
auto eth1
iface eth1 inet dhcp
Lastly, $ sudo ifup eth1, reboot and you're done. Don't forget to change eth1 with the name of your Ethernet interface.
Original answer
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
Whatnow
  • 71
tl;dr
First, edit this file
sudo vim /etc/resolvconf/resolv.conf.d/base
Second, Add the following
nameserver 8.8.8.8
nameserver 8.8.4.4
After that, restart Ubuntu, should have internet now.
Explain
Some of the solution listed worked, but will failed once restart Ubuntu (in my case, VM),
The above solution is a tl;dr form this solution (https://unix.stackexchange.com/a/128223/243480) and it worked perfectly
I was having the same issue on ubuntu 18.04 and the above answer didn't work for me as I didn't have a folder named /etc/resolvconf/resolv.conf.d/. So I did the following
sudo mkdir -p /etc/resolvconf/resolv.conf.d
sudo touch /etc/resolvconf/resolv.conf.d/head
Then I added nameserver 8.8.8.8 to the file /etc/resolvconf/resolv.conf.d/head
Then a simple network restart solved the issue.
On the non-working updated PC the symlink was :
/etc/resolv.conf -> /run/resolveconf/resolv.conf
On a working PC with 18.04 the symlink was :
/etc/resolv.conf -> /run/systemd/resolve/stub-resolv.conf
then I replace the old linked file with a new one :
rm  /etc/resolv.conf
sudo ln -s  /run/systemd/resolve/stub-resolv.conf  /etc/resolv.conf
(work after procedures described below)
Covich
  • 273
Changing /etc/resolv.conf is not the best answer to this problem. According to Ubuntu 16.04 documentation resolv.conf file can be overwritten by system at any time.
If you are using static IP configuration you should add one line to you /etc/network/interfaces file in you ethernet card configuration. It should look something like:
iface eth0 inet static
    address 192.168.3.3
    emsp;netmask 255.255.255.0
    gateway 192.168.3.1
    dns-nameservers 8.8.8.8
And then to restart your network run:
If you want to avoid any possible problems in the future, you can do one more thing. Upgrading from 16.04 to 18.04 does not change network configuration method from /etc/network to new /etc/netplan used in 18.04. If you want to change it manually look at How to enable netplan on ubuntu server upgraded from 16.04 to 18.04
abu_bua
  • 11,313
Hello All Almost total noob here but I ran into this problem when I started dual booting between Windows 10 and loaded Ubuntu 18.04 on a separate hard drive. My internet wouldn't connect and my router wouldn't allow me to open up the configuration interface. I finally figured out that it was because I had DCHP set to assign a static IP to Windows 10. After checking all the information I could find and nothing working I loaded Windows 10 and removed the routers static IP from the DHCP settings. That got internet working but I wanted a static IP for Windows and Ubuntu. Best I can figure is that Ubuntu doesn't take the hand off from the routers DHCP server properly despite being set to automatic. Once I manually configured the static IP address and Gateway in Ubuntu could I go back to having aforesaid static IP. Hope this helps someone. Drew
In my case, i have tried many answers, unfortunately, all can not work in my computer. Here is my solution. I think no internet after upgrade from 16.04 to 18.04, this problem is most likely caused by the loss of the network driver. What you need to do is to reinstall it. Visit this link intel network driver, and download the driver. The version I am using is e1000e-3.8.4, i haven't tried whether other version can work. After downloading, extract this file to a folder. Enable root privileges:
sudo -i
Then, enter the src directory.
cd e1000e-3.8.4/src/
Note that you should change the version if you use a different driver. Compile the driver module.
make install
If this step is successful, it is good. But here i meet a problem.
 error: redefinition of ‘skb_frag_off’
To solve this problem, you can open this file: src/kcompat.h. In this file, there is a function, skb_frag_off, comment it. And then type make install again, this should work. Finally, enter
modinfo e1000e
modprobe e1000e [parameter=port1_value,port2_value]
At this point, you should be able to connect to the network normally.
LOTEAT
  • 101
-1
I solved a connection failure after an upgrade by using a wireless connection using a USB-attached network adapter, then changing to the preferred wired connection directly to the router.
K7AAY
  • 17,705
wubetu
