After running apt update, apt upgrade and apt autoremove I tried running do-release-upgrade. It failed with the message:
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by:
- Unofficial software packages not provided by Ubuntu
Please use the tool 'ppa-purge' from the ppa-purge
package to remove software from a Launchpad PPA and
try the upgrade again.
If none of this applies, then please report this bug using the
command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal. If
you want to investigate this yourself the log files in
'/var/log/dist-upgrade' will contain details about the upgrade.
Specifically, look at 'main.log' and 'apt.log'.
I tried running ppa-purge and get a syntax summary.
I looked at the two log files and they didn't tell me what ppa is causing the problem.
apt.log is over 4000 lines. Here are the last few:
Starting pkgProblemResolver with broken count: 2
Starting 2 pkgProblemResolver with broken count: 2
Investigating (0) lightdm-settings:amd64 < 1.1.4-0ubuntu1 @ii mK Ib >
Broken lightdm-settings:amd64 Depends on python3-xapp:amd64 < 1.0.1-1 | 1.6.0-1 @ii ugR >
Considering python3-xapp:amd64 1 as a solution to lightdm-settings:amd64 1
Removing lightdm-settings:amd64 rather than change python3-xapp:amd64
MarkDelete lightdm-settings:amd64 < 1.1.4-0ubuntu1 @ii mK Ib > FU=0
Investigating (0) ubuntu-desktop:amd64 < 1.417.4 -> 1.440.1 @ii pumU NPb Ib >
Broken ubuntu-desktop:amd64 Depends on ubuntu-desktop-minimal:amd64 < none | 1.440.1 @un uH >
Considering ubuntu-desktop-minimal:amd64 1 as a solution to ubuntu-desktop:amd64 0
Ignore MarkKeep of ubuntu-desktop:amd64 < 1.417.4 -> 1.440.1 @ii pumU NPb Ib > as its mode (Install) is protected
Re-Instated ubuntu-desktop-minimal:amd64
Re-Instated ubuntu-desktop:amd64
Done
MarkInstall ubuntu-mate-desktop:amd64 < 1.225 -> 1.257 @ii ugU NPb IPb > FU=1
ignore old unsatisfied important dependency on ffmpegthumbnailer:amd64
new important dependency: gnome-mpv:amd64
Installing gnome-mpv as Recommends of ubuntu-mate-desktop
MarkInstall gnome-mpv:amd64 < none -> 0.16-1ubuntu1 @un uN Ib > FU=0
Installing libmpv1 as Depends of gnome-mpv
MarkInstall libmpv1:amd64 < none -> 0.29.1-1ubuntu1 @un uN IPb > FU=0
Installing youtube-dl as Recommends of libmpv1
MarkInstall youtube-dl:amd64 < none -> 2019.09.28-1 @un uN IPb > FU=0
Installing mpv as Recommends of youtube-dl
MarkInstall mpv:amd64 < none -> 0.29.1-1ubuntu1 @un uN > FU=0
Installing python3-pyxattr as Recommends of youtube-dl
MarkInstall python3-pyxattr:amd64 < none -> 0.6.1-1 @un uN > FU=0
previously satisfied important dependency on gufw:amd64
Installing gufw as Recommends of ubuntu-mate-desktop
MarkInstall gufw:amd64 < 18.04.0-0ubuntu1 -> 19.04.0-0ubuntu1 @ii ugU Ib > FU=0
Installing ufw as Depends of gufw
MarkInstall ufw:amd64 < 0.36-0ubuntu0.18.04.1 -> 0.36-1ubuntu3 @ii ugU > FU=0
previously satisfied important dependency on lightdm-settings:amd64
Installing lightdm-settings as Recommends of ubuntu-mate-desktop
MarkKeep lightdm-settings:amd64 < 1.1.4-0ubuntu1 @ii gR > FU=0
previously satisfied important dependency on redshift-gtk:amd64
Installing redshift-gtk as Recommends of ubuntu-mate-desktop
MarkInstall redshift-gtk:amd64 < 1.11-1ubuntu1 -> 1.12-2 @ii ugU > FU=0
previously satisfied important dependency on rhythmbox-plugin-alternative-toolbar:amd64
Installing rhythmbox-plugin-alternative-toolbar as Recommends of ubuntu-mate-desktop
MarkInstall rhythmbox-plugin-alternative-toolbar:amd64 < 0.18.0-1 -> 0.18.4-1 @ii ugU > FU=0
Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Considering python3-xapp:amd64 1 as a solution to lightdm-settings:amd64 3
Added python3-xapp:amd64 to the remove list
Fixing lightdm-settings:amd64 via keep of python3-xapp:amd64
MarkKeep python3-xapp:amd64 < 1.0.1-1 | 1.6.0-1 @ii ugR > FU=0
Done
Log time: 2020-04-29 19:49:21.097217
The site software won't let me post main.log due to too many links in the file.
