If we have access to a server with public IP address, then we can use it as a gateway. We could achieve this via Reverse SSH Port Forwarding connections. Let’s say we have three instances:
Public Server: Here we have an operational SSH server and public IP address (and/or domain name). We are able to connect to this server with public-private key pair, which is not passphrase protected (setup reference).
Private Server: Here we have an operational SSH server. It is behind a Firewall (NAT, ISP, etc.) and doesn't have a public IP address, but we are able to establish a SSH connection from it to the Public Server, so here we have also SSH client.
Client Machine: Here we (need to) have only SSH client. We are able to establish a SSH connection to the Public Server. We want to establish a SSH connection from this instance to the Private Server.
The principal level
At principal level we could apply at least two scenarios.
Scenario 1. Where we don’t want to open an additional ports in the Public Server’s Firewall:
- Establish SSH connection with Port Forwarding from the Private Server to the Public Server.
- Establish SSH connection with Port Forwarding from the Client Machine to the Public Server.
- Connect to the Private Server from the Client Machine via the forwarded port (through itself).
Scenario 2. Where we are inclined to open an additional port in the Public Server’s Firewall:
- Connect to the Private Server from the Client Machine through the Public Server.
The main advantage of the Scenario 1 is that we don’t need to think how secure is our Private Server. The main advantage of the Scenario 2 is that we ommit one step, but in this case we should think about the security of the Private Server, because it becomes public accessible through the forwarded port. In addition, these scenarios could be applied to different port and services, not only SSH, for example to HTTP.
How to apply Scenario 1 within Ubuntu
We could do that by the command:
ssh user-of-the-public-server@public-server -p 22 -R 2222:127.0.0.1:22 -i ~/.ssh/pass-less/id_rsa
-p 22 provides the SSH port of the Public Server (it is not mandatory).
-i ~/.ssh/pass-less/id_rsa provides the authentication key file.
-R 2222:127.0.0.1:22 means that port 2222 on the (remote) Public Server will be forwarded to the SSH port of the (local) Private Server that, in this case, is 22.
We can push this connection into the background by adding the options -fTN (of the OpenSSH Client – reference). We could use also the tool autossh to be sure the connection will be kept alive for a long period of time (reference):
autossh user-of-the-public-server@public-server -p 22 -fTN -R 2222:127.0.0.1:22 -i ~/.ssh/pass-less/id_rsa
We can simplify the above command by implementation of the following lines in our ~/.ssh/config file:
Host public-server-reverse
HostName 100.100.100.100
IdentityFile ~/.ssh/pass-less/id_rsa
User user-of-the-public-server
Port 22
RemoteForward 2222 localhost:22
- 100.100.100.100 is the IP address or the domain name of the Public Server
In this case the above command will become:
autossh public-server-reverse -fTN
We can easily automate this task on system reboot by the next Cron job (or we could create service that should be the better approach):
@reboot sleep 45 && autossh public-server-reverse -fTN
Once this connection is established we can connect to the Private Server from the Public Server, through the reverse tunnel, by the command:
ssh user-of-the-private-server@localhost -p 2222 # provide an additional authentication data (for the Private Server) if it is needed…
ssh user-of-the-public-server@public-server -p 22 -fTN -L 1111:127.0.0.1:2222 -i ~/.ssh/pass-less/id_rsa
-L 1111:127.0.0.1:2222 means that port 1111 on the (local) Client Machine will be forwarded to the (remote) Public Server’s port 2222 (that is forwarded to the SSH port of the Private Server). Note we could use -L 2222:127.0.0.1:2222.
-fTN these options will push the connection into the background as it is described above.
We can implement also autossh and ~/.ssh/config file, with directive RemoteForward or LocalForward.
Connect to the Private Server from the Client Machine through itself
Once the above two steps are implemented, we can connect from the Client Machine to the Public Server by the command:
ssh user-of-the-private-server@localhost -p 1111 # provide an additional authentication data (for the Private Server) if it is needed…
How to apply Scenario 2 within Ubuntu
This step is identical as the first one from the Scenario 1, but few additional things should be done.
Open the forwarded port 2222 on the Public Server’s Firewall - this is out of the scope of this answer.
Modify /etc/ssh/sshd_config of the Public Server and add the next directive, that will allow to open our SSH tunnel to public (don't forget to restart the server: sudo systemctl restart sshd.service):
GatewayPorts yes
Make our SSH tunnel open to public. This step is well described within the question: (How to make ssh tunnel open to public?). According to the answers there we could add the -g option to the commands that make a connection between the Private and the Public servers:
autossh public-server-reverse -gfTN
@reboot sleep 45 && autossh public-server-reverse -gfTN
Or, alternatively, instead that we could modify the ~/.ssh/config file in this way:
Port 22
RemoteForward \*:2222 localhost:22
Finally we should killall autossh and establish the connection again.
Once the above step is performed, we can achieve our goal by the command:
ssh user-of-the-private-server@public-server -p 2222 # provide an additional authentication data (for the Private Server) if it is needed… forward some ports, etc.
Update
In case the Public Server and the Private Server are in the same LAN you could use either of the options ProxyCommand or ProxyJump. The option ProxyJump is available at OpenSSH 7.4+, with this option you could easily pass through multiple gateways. Here is few examples:
ssh -J PublicServer PrivateServer
ssh -J user1@PublicServer:port1 user2@PrivateServer -p port2
ssh -J user1@PublicServer:port1,user2@IntermediateServer:port2 user3@PrivateServer -p port3
Or if you would prefer to use ~/.ssh/config entry:
Host PublicServer
IdentityFile ~/.ssh/public_server_id_rsa
User User1
Port 10222
Host PrivateServer
HostName 172.16.1.100
IdentityFile ~/.ssh/private_server_id_rsa
User User2
Port 22
ProxyJump PublicServer
Note, the both SSH keys are stored at the Client Machine.
100.100.100.100 is the IP address or the domain name of the Public Server. 172.16.1.0/24 is the LAN where the Private Server is accessible by the Public Server. And 172.16.1.100 is the LAN IP address of the Private Server.
Then, in order to connect to the Private server, just use:
ssh PrivateServer
