I'm assuming you are working on machine A. From there you can connect to machine B. And from B you can connect to machine C. That you want is to establish a connection directly from machine A to machine C. Here is my suggestion:
Create SSH connection from machine B to machine C and forward a local port on B (20022 - for example) to the remote SSH port on C (22).
machine-b~$ ssh machine-c -L 20022:127.0.0.1:22 -fTN
Or issue the command through SSH directly from machine A:
machine-a~$ ssh machine-b "ssh machine-c -L 20022:127.0.0.1:22 -fTN"
Create SSH connection from machine A to machine B and forward a local port on A (10022) to the remote port 20022 on B.
machine-a~$ ssh machine-b -L 10022:127.0.0.1:20022 -fTN
Create SSH connection or use SSHFS from A to its loopback iface (127.0.0.0/localhost) on port 10022 to connect to C.
machine-a~$ ssh -p 10022 <machine-c-user>@localhost
machine-a~$ sshfs -p 10022 <machine-c-user>@localhost:/target/dir/ /dest/dir/
According to this scenario below are presented few little bit more advanced ideas and explanations.
1. Setup machine B to connect to machine C by using ssh key pair (without passphrase), if this is not previously done. For this purpose use the following sequence:
SSH to machine B and generating RSA key pair, don't enter passphrase:
mkdir -p ~/.ssh/machine-c-key/
chmod 700 ~/.ssh
chmod 700 ~/.ssh/machine-c-key/
ssh-keygen -t rsa -b 4096 -f ~/.ssh/machine-c-key/id_rsa # do not enter passphrase
chmod 600 ~/.ssh/machine-c-key/id_rsa
Transfer the id_rsa.pub key into the ~/.ssh/authorized_keys file on machine C, by using ssh-cipy-id. On machine B execute the command:
ssh-copy-id -i ~/.ssh/machine-c-key/id_rsa '<user>@<machine-c>' -p '22'
Now try logging into the machine C, with:
ssh -i ~/.ssh/machine-c-key/id_rsa -p '22' '<user>@<machine-c>'
If this works, if you wish, edit /etc/ssh/sshd_config and set: PasswordAuthentication no
Copy the generated key from machine B to machine A, we will use it later. On machine A use rsync in the following way (pay attention to the slashes /):
rsync -r machine-b:/home/<user>/.ssh/machine-c-key ~/.ssh/
Deal with the permissions (on machine A):
chown -R $(id -u):$(id -g) ~/.ssh
2. Create ~/.ssh/config file on machine B, and setup port forwarding. Add these lines into the mentioned config file:
Host machine-c-port-fwd
HostName 192.168.100.100
IdentityFile ~/.ssh/machine-c-key/id_rsa
User user
Port 22
LocalForward 20022 127.0.0.1:22
- You should provide the actual IP-address or domain name of machine C and the actual user.
- The
Port 22 is the ssh port on machine C.
- The directive
RemoteForward 20022 127.0.0.1:22 means that the port 22 of remote loopback interface (on machine C) will be forwarded to port 20022 on machine B.
- Note if you already have configuration for
Host machine-c it is a good idea to create a separate one for the port forwarding setup.
Now you should be able to connect to machine C from machine B by using of the command:
ssh machine-c-port-fwd
We can push this connection into the background by adding the options -fTN (reference). We could use also the tool autossh to be sure the connection will be kept alive for a long period of time (sudo apt install autossh - reference):
autossh machine-c-port-fwd -fTN
- Use
killall autossh to disable it :)
At this stage you should be able to connect to machine C from machine B through its loopback interface:
ssh -i ~/.ssh/machine-c-key/id_rsa -p '20022' '<machine-c-user>@localhost'
3. Establish connection from machine A to machine C (through the machine B). Perform the following steps on machine A:
Issue a command via SSH to machine B to establish a connection to machine C:
ssh machine-b "autossh machine-c-port-fwd -fTN"
Establish SSH connection to machine B (from A) with port forwarding and push the connection into the background:
autossh machine-b -L 10022:127.0.0.1:20022 -fTN
In this way the local port 10022 (on machine A) will be forwarded (bind) to the remote port 20022 (on machine B) that is bind to port 22 on machine C. We can use the same port number (20022 - for example) on A and B...
Note that everywhere we are limit the port forwarding only to the loopback interface (127.0.0.1), but this could be done for all interfaces (0.0.0.0 or \*) or for certain interface (by using its IP).
You can create ~/.ssh/config file on machine A, analogical to the description in section 2, to simplify your commands in the future. Alco I would prefer to use SSH key based authentication...
Connect to machine C from machine A through its (on machine A) loopback interface:
ssh -i ~/.ssh/machine-c-key/id_rsa -p '10022' '<machine-c-user>@localhost'
Or use SSHFS in this way (note, sshfs can use the hosts from ~/.ssh/config):
sshfs -p 10022 <machine-c-user>@localhost:/target/dir/ /destination/dir/ -o IdentityFile=~/.ssh/machine-c-key/id_rsa
To automate the execution of the above three commands you can create a function as the follow in your ~/.bashrc file:
mount-machine-c() {
ssh machine-b "autossh machine-c-port-fwd -fTN" && sleep 1
source ~/.bashrc and mount-machine-c will be available as shell command. You can add additional logic and arguments to test whether /destination/dir/ is already mounted, etc...
