16
Ubuntu 17.10 (xorg), GNOME 3.26.2, Firefox 58.0 (64 bit).
I have a few Firefox profiles setup. When I run each profile, I would like it to be a separate icon on the dock. How do I make that happen? Right now what happens is that they are all grouped in the standard Firefox icon.
pomsky
  • 70,557
dln949
  • 1,345
Edit profile's .desktop file:
The string SomeClass must be the same in both changes.
Example .desktop file:
[Desktop Entry]
Name=Firefox Test
Exec=firefox -p test -no-remote --class FxTest
Terminal=false
Type=Application
StartupNotify=true
Icon=/path/to/custom/icon.png
StartupWMClass=FxTest
Added in 2022
For Snapped Firefox you can try Parallel Installs:
  1. sudo snap set system experimental.parallel-instances=true
  2. reboot
  3. sudo snap install firefox_parallel --unaliased
  4. cp /var/lib/snapd/desktop/applications/firefox+parallel_firefox.desktop ~/.local/share/applications/
  5. gedit ~/.local/share/applications/firefox+parallel_firefox.desktop
For Wayland, use --name SomeClass. Like --class, --name is defined by GTK and is not documented by Firefox.
grisfer
  • 535
Copy the firefox icon file.
cp /usr/share/applications/firefox.desktop \
   /usr/share/applications/firefox-dev.desktop
In the new file edit 4 lines, using the full path for the executable and icon. The icon shown below is a blue colored version of the firefox icon.
[Desktop Entry]
Exec=/opt/firefox-dev/firefox
Icon=/opt/firefox-dev/browser/chrome/icons/default/default128.png
[Desktop Action new-window]
Exec=/opt/firefox-dev/firefox -new-window
[Desktop Action new-private-window]
Exec=/opt/firefox-dev/firefox -private-window
Then follow the instructions here to put the new icon file in the gnome registry.
sudo apt install dconf-editor
dconf-editor
Navigate to org.gnome.shell favorite-apps and add in your new icon
[ ..., 'firefox.desktop', 'firefox-dev.desktop', ... ]
It may necessary to log out and log back in before using the icon.
Worked on Ubuntu 22.04
The only way I managed to make 2 independently firefox shortcuts in the dock (one of them with different icon), where its windows are gathered with its corresponding icon, was to install a deb firefox along with the snap firefox.
#Disable snap firefox
sudo snap disable firefox
sudo apt remove --autoremove firefox -y
########################## #Install .deb firefox sudo add-apt-repository ppa:mozillateam/ppa -y sudo apt-get update -y sudo apt-get upgrade -y #Set firefox updates priority for the .deb repository sudo bash -c 'cat > /etc/apt/preferences.d/99mozillateamppa <<EOF Package: firefox* Pin: release o=LP-PPA-mozillateam Pin-Priority: 501
Package: firefox* Pin: release o=Ubuntu Pin-Priority: -1 EOF' sudo apt install -t 'o=LP-PPA-mozillateam' firefox -y #the deb is installed in /usr/lib/firefox
enable snap firefox again
sudo snap enable firefox #########################
change firefox icon
old="Icon=firefox" new="Icon=/path/to/your/icon" sudo sed -i "/${old}/c ${new}" /usr/share/applications/firefox.desktop
#change .deb firefox name old="Name=Firefox Web Browser" new="Name=FirefoxSecond" sudo sed -i "/${old}/c ${new}" /usr/share/applications/firefox.desktop
To open firefoxSecond (.deb) :
firefox
To open firefox( snap) :
snap run firefox
Now add them to favorites!
Vitor Abella
  • 8,015
  • 16
  • 63
  • 115
