The WMClass seems to have no authority when it comes to Chromium... I came up with this abomination (personal opinion... I'd just like for it to work with sh :) ) It has a few tricks, but is pretty robust for two windows.. The script sets individual classes for the opened chromium windows (not profiles, even though that is what I am after) You could specify further windows too, but they have to be manually added by adding more "specificprofile1" along with the corresponding function.. Maybe someone could make it have more.. logic!
#!/bin/bash
# chromium-start.sh $1
# e.g. put:
# chrome-start.sh "Profile 1" to .desktop Exec=
# wmctrl -o 1366,0 ; chromium-browser %U --profile-directory=Profile\ 2 & sleep 3; wmctrl -o 0,0
# $1 = Profile folder name
profilename=$1
#2nd Chromium profile
specificprofile1="Profile 1"
echo "starting Chromium"
echo "args: " $1
echo "Profile name: " $profilename
echo "Specific profile: " $specificprofile1
# Just setting Chromium scaling variable, because of course Google Devs don't care about no fractional scaling on linux
scale_var=0.8
# Check if Chromium window with the specified class already exists
# Also allows using icons as "taskbar" switches (clicking icon takes to corresponding Chromium Window)
if wmctrl -l -x | grep "chromium-$profilename"
then
echo "Chromium Window exists, moving focus to it"
wmctrl -x -R chromium-"$profilename"
echo "true"
# Check if 2nd profile $specifiedprofile1 has been started yet or not. The WMCLASS(es) has to have been set correctly...
elif [[ "$specificprofile1" == "$profilename" ]] && [[ ! "`wmctrl -l -x | grep chromium-"$specificprofile1"`" ]]
then
# TODO: Nesting
if [ "$specificprofile1" == "$profilename" ]
then
echo $specificprofile1 "equals" $profilename
fi
echo "#2 Chromium Window for $specificprofile1 does not exist"
# wmctrl moves to specific position of desktop (1366 means moving to the following workspace since my resolution is 1366x768)
# Be careful if using sleep timing, since the command needs to have enough time to execute to have the window in the correct workspace
wmctrl -o 1366,0
chromium-browser --profile-directory="$profilename" --force-device-scale-factor=$scale_var %U &
# https://askubuntu.com/a/626524/654028
# Set's the chromium window which was opened latest to have a custom class, since Chromium doesn't care about the --class= flag...
# It has it's limitations, but should be robust enough for most use... Has not been tested long term.. Something probably could reset the WM_CLASS again
# xprop -id "$(wmctrl -l -x| grep "chromium-browser" | tail -n 1 |awk '{ print $1 }')" -f WM_CLASS 8s -set WM_CLASS "chromium-browser.chromium-$specificprofile1"
# Alternative method for checking if a window with specified class exists
# xprop -id "$(wmctrl -l -x| grep "chromium-$profilename" | tail -n 1 |awk '{ print $1 }')" | grep -o "WM_CLASS(STRING) = ".*"" | grep -o '".*"' | tr -d '"'
# https://stackoverflow.com/a/19441380/5776626
winrep=""
while [[ ! "`echo $winrep | grep -l "Map State: IsViewable"`" ]]
do
winid="$(wmctrl -l -x| grep "chromium-$profilename" | tail -n 1 |awk '{ print $1 }')"
# print $winid
winrep="$(xwininfo -id $winid | grep -o 'Map State: IsViewable')"
# print $winrep
sleep 0.75
done
# sleep 3
# Move Window directly to workspace (#2 with 1366x768 resolution x = 1366), optionally comment out wmctrl -o 1366,0
# wmctrl -v -i -r $winid -e 0,1366,0,-1,-1
# sleep 5
# Move back to workspace #1
wmctrl -o 0,0
elif ! wmctrl -l -x | grep chromium-"$profilename"
then
echo "#3 Chromium Window $profilename does not exist"
wmctrl -o 0,0
# sleep 3
winrep=""
do
# print $winid
# print $winrep
sleep 0.75
xprop -id "$(wmctrl -l -x| grep "chromium-browser" | tail -n 1 |awk '{ print $1 }')" -f WM_CLASS 8s -set WM_CLASS "chromium-browser.chromium-$profilename"
done
wmctrl -o 0,0
# xprop -id "$(wmctrl -l -x| grep "chromium-browser" | tail -n 1 |awk '{ print $1 }')" -f WM_CLASS 8s -set WM_CLASS "chromium-browser.chromium-$profilename"
fi
Issues:
Printing gives errors (deprecation warnings..):
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/%{ <-- HERE (.*?)}/ at /usr/bin/print line 528.
For debugging you can use the following to print out the errors when using actual icons:
https://askubuntu.com/a/664272/654028 (# The Manual alternative)
awk '/^Exec=/ {sub("^Exec=", ""); gsub(" ?%[cDdFfikmNnUuv]", ""); exit system($0)}' chrome-ws2.desktop
while loop bugs out, probably because of looping interval
Error: no such file "at while function"
xwininfo: error: -id requires argument
xprop: error: Invalid window id format: .
Also when clicking a corresponding .desktop icon too fast (before the custom class has been set ?), a new window will be opened..
(quite) Sometimes when starting from both Chromium too fast (~<3s), the class of the previously opened window gets reset to chromium-browser.chromium-browser..
Then you can expect the icons to have swapped around or other unexpected behavior.
