We have a quantity $a$ expressed in terms of two quantities $b $ and $c$ as $a = b/c$. It seems to me that there are two ways of estimating the error on $a$, the "physics" prescription and a "maths" one based on differentiation:
  1. According to "physics": $∆a/a = ∆b/b + ∆c/c$
  2. According to "math" (namely, using differentiation): $da/a = db/b - dc/c$
Which is wrong?
Consider two positive quantities $b>0$ and $c>0$ with associated "small errors" $\delta b>0$ and $\delta c>0$, and
$$a(x) = \dfrac{b+x \delta b}{c-x \delta c}$$
where $x\in(-1,1)$ is an extra parameter that works as a sort of "bookmark": $x$ keeps track of the "small" elements in the expression, namely $\delta b$ and $\delta c$. In which range do we expect $a(x)$ to vary? The minimum is for $x=-1$ (minimize the numerator and maximize the denominator!) and the maximum is for $x=1$: $$ a_m = \dfrac{b- \delta b}{c+ \delta c} < a(x) < \dfrac{b+ \delta b}{c- \delta c}=a_M $$
To the linear order in $x$ (we can do this despite the fact that $x$ is not necessarily small because $x$ bookmarks the small errors!), we have $$ a(x) \approx \dfrac{b}{c}+x \dfrac{c \, \delta b + b \, \delta c}{c^2}+ O(x^2) $$ In the above expression, $O(x^2)$ means that we stop the expansion before quantities like $(\delta b)^2$, $(\delta c)^2$, $ \delta b \,\delta c $ appear. In this approximation, $a_m$ and $a_M$ still correspond to $x=- 1$ and $x=1$, so that $$ a_m \approx \dfrac{b}{c}- \dfrac{c \, \delta b + b \, \delta c}{c^2} \qquad \qquad a_M \approx \dfrac{b}{c}+ \dfrac{c \, \delta b + b \, \delta c}{c^2} $$ In the end, we obtain the expression for $\delta a>0$ by considering the half-distance between $a_m$ and $a_M$: $$ \delta a = \dfrac{a_M-a_m}{2}\approx \dfrac{c \, \delta b + b \, \delta c}{c^2} = \dfrac{ \delta b}{c} + a \dfrac{\delta c}{c} \quad \Rightarrow \quad \dfrac{\delta a}{a} \approx \dfrac{ \delta b}{b} + \dfrac{\delta c}{c} $$
Extra: You may use the same method to justify the error propagation for the product $a=bc$ by considering $$a(x)=(b+x \delta b)(c+x\delta c)$$ for $0<\delta b <b$ and $0<\delta c <c$. Again, $a_m=a(-1)$ and $a_M =a(1)$ and $\delta a =(a_M-a_m)/2$. The formula to the linear order in $x$ is the same as the one for the quotient discussed above, see this.
Important note: The theory of propagation of uncertainty and the (more advanced) uncertainty quantification provide a better (statistical) justification for this simple result, as well as its validity range.
"Quadratic" approach (see the comments) - Given a random variable $X$ that is a linear combination of other two random variables, e.g. $X=sY+rZ$, we have that (see this for the proof or Wikipedia):
$$ Var(X) = s^2Var (Y) + r^2Var(Z) + 2sr Cov(Y,Z) $$
where the covariance is: ${Cov}(Z,Y) = {E}\left[ (Z-{E}[Z]) (Y-{E}[Y]) \right]$.
Now, if $X=f(Y,Z)$, we can use the above formula if we take the linear approximation $dX \approx \partial_Y f dY + \partial_Z f dZ $: we have that $s=\partial_Y f$ and $r=\partial_Z f$. The deviations $dX$, $dY$, $dZ$ are legit random variables: $dX= X-f(E(Y),E(Z))$, $dY=Y-E(Y)$, $dZ=Z-E(Z)$, where $E$ denotes the expected value. Moreover, $Var(X+c)=Var(X)$ for any constant $c$, so that $Var(X)=Var(dX)$. the same is valid for $Y,Z$.
In the end:
$$ Var(X) = Var(dX) \approx (\partial_Y f)^2 Var(Y)+ (\partial_Z f)^2 Var(Z) + 2 (\partial_Y f)( \partial_Z f) Cov(Y,Z) $$
We can apply this formula to $a=bc$ (the case $a=b/c$ is analogous): $c$ plays the role of the random variable $X$ and the values $a,b$ are realizations of the random variables $Y,Z$. We also assume that $Y,Z$ are independent (so their covariance is zero). Therefore, $f=bc$, $\partial_bf=c$, $\partial_cf=b$ (for consistency, these derivatives are formally calculated at the observed/expected value) and
$$ Var(a) \approx b^2 Var(c)+ c^2 Var(b) \qquad \Rightarrow \qquad \dfrac{Var(a)}{a^2} \approx \dfrac{Var(c)}{c^2} + \dfrac{Var(b)}{b^2} $$
You may be surprised to see that the result is quadratic, but this is not mysterious: Why is propagation of uncertainties quadratic rather than linear?. As said, the simple prescription discussed in the first part of this answer is just a convenient approximate way of estimating the expected interval in which the variable $a$ can vary. Better estimation of the variance of $X$ can be given by considering the algebra of random variables.
Quillo
  • 5,541
  • 19
  • 46
There is nothing wrong with the equation $\dfrac {\delta a}{a} = \dfrac {\delta b}{b} - \dfrac {\delta c}{c} $ provided it is used correctly and it is equivalent to $\dfrac {\Delta a}{a} = \dfrac {\Delta b}{b} + \dfrac {\Delta c}{c} $.
At first sight the equation $\dfrac {\delta a}{a} = \dfrac {\delta b}{b} - \dfrac {\delta c}{c} $ seems all wrong for calculating errors particularly if the fractional changes in $b$ and $c$ are equal as that gives a fractional change in $a$ of zero.
Does that really mean that the fractional error in $a$ is zero?
The answer is yes, that could be true.
But what are you actually looking for?
With simple error analysis one is looking for the maximum possible fractional error in $a$ given fractional errors in $b$ and $c$.
If $a=\dfrac bc$ how does one compute the maximum value of $a$?
It is done by evaluating $\dfrac{\text{maximum value of b}}{\text{minimum value of c }}= \dfrac {b+\delta b}{c-\delta c}$.
Similarly the minimum value of $a$ would be $\dfrac {b-\delta b}{c+\delta c}$.
So if one were to use the equation $\dfrac {\delta a}{a} = \dfrac {\delta b}{b} - \dfrac {\delta c}{c} $ one would have to assign the appropriate signs to $\delta b$ and $\delta c$ to maximize (or minimise) the fractional change in $a$.
Thus for a maximum, $\delta b$ would be positive and $\delta c$ would be negative.
Rather than go through all this palaver, for error analysis the equation $\dfrac {\Delta a}{a} = \dfrac {\Delta b}{b} + \dfrac {\Delta c}{c} $ is used with $\Delta b$ and $\Delta c$ both being positive which immediately gives the maximum fractional error in $a$.
Farcher
  • 104,498
