In one of my labs I had to calculate the an expression for a constant $m$, where $m$ is defined as $m = \frac{T}{L^2v^2}$, with $T$ being tension (constant), $L$ being length and $v$ being frequency. Now in order to do this accurately, I found 6 values for $L$ and $v$ - the tension was constant for all of these values. Then I used excel to plot a graph of $T$ against $L^2v^2$ and the gradient of the line of best fit gave me my value for $m$. Now the thing that I'm having problems with is finding out if it's possible for me to find the uncertainty on $m$. I know that I can find the uncertainty for $m$ if I know the uncertainties for $T$, $L^2$ and $v^2$ using the formula below:
$$\left. \begin{array}{l} Z = A \times B \\ or \\ Z = \frac{A}{B}\\ \end{array} \right\} \Rightarrow \biggl (\frac{\Delta Z}{Z} \biggr )^2 = \biggl (\frac{\Delta A}{A} \biggr )^2 + \biggl (\frac{\Delta B}{B} \biggr )^2$$
I'm able to calculate the uncertainty on $T$ but I'm not sure if I can calculate the uncertainties for $v^2$ and $L^2$. I know that the uncertainties for each value of $v$ and $L$ were $\pm 0.1$ Hz and $\pm 0.05$ Hz. However, in order to calculate the uncertainties for $v^2$ and $L^2$ I need to use the formula:
$$Z = A^n \Rightarrow \frac{\Delta Z}{Z} = n \biggr ( \frac{\Delta A}{A} \biggl )$$
which requires values for $v$ and $L$, which I do not have since I used the gradient of the line of best fit to find $m$ and not specific values of $L$ and $v$. So I'm wondering if it would be sensible for me to perhaps use the average of my values for $L$ and $v$ in order to calculate the uncertainties for $L^2$ and $v^2$ or if it is sensible at all to even calculate an uncertainty for $m$ in this situation.
Hai
  • 131
Absolute error of function is defined as : $$ \Delta_f = \sum_n \left| \frac{\partial f(x_1,x_2,\ldots, x_n)} {~\partial x_n} \right| \cdot \Delta {x_n} $$
And relative error of function is just : $$ \delta_f = \frac{\Delta_f}{\left|f(x_1,x_2,\ldots, x_n)\right|} $$
So for your function : $$ m = \frac{T}{L^2v^2} $$ with two variables $L,v$, find partial derivatives with respect to them and substitute into first formula for absolute error :
$$ \Delta_m = \frac {2~T}{L^3 v^2} \Delta L ~+~ \frac{2~T}{L^2 v^3}\Delta v $$
Substitute average values of $L,v,T$ and measurement errors $\Delta L,\Delta v$ and you will get $m(L,v)$ function absolute error. If you need a relative error, then according to second formula - just divide found absolute error by $m$ function value.
