I was recently learning about the the second quantization of the Schrödinger field, and naturally got interested in how it aligns with the field theoretic path integral. So just as a short introduction.
What one can do is coming from the Lagrangian
$$\mathcal{L} = \psi^{*}(x)\left(i\hbar\partial_t +\frac{\hbar^2}{2m}\Delta -V(x)\right)\psi(x)\tag{46.1}$$
and from here do a quite regular canonical quantization. This is for example described in chapter 46 of the book "Quantum Mechanics" by Leonard I. Schiff. As it can be downloaded from this source: http://www.fulviofrisone.com/attachments/article/480/Schiff%20L.I.%20Quantum%20mechanics%20(MGH,%201949)(T)(417s).pdf
On the other hand, unrelated to this, there is a derivation of a configuration space path integral for a Schrödinger Wavefunction. Technically, one comes from the desire to construct an integration kernel s.t.
$$\psi(q', t')=\int dq K(q', q, t-t') \psi(q, t).$$
After applying some cool tricks, one comes to the conlcusion that:
$$K(q, q', t-t')= \int_{w(t)=q}^{w(t')=q'} Dw e^{iS[w]/\hbar}$$
Where
$$S[w] = \int_t^{t'} \frac{m \dot{w}^2}{2}-V(w)$$
is the classical action. So this got me curious. If first I do canonical quantization and then retrieve this formula for the path integral with that Kernel? The answer is yes, and what you find is that
$$\langle \psi^\dagger(q', t') \psi(q, t) \rangle = K(q, q', t-t').$$
Then I asked myself: Can I retrieve this path integral from the second-quantized field-theoretic path integral?
So from
\begin{equation} Z=\int D\psi^{*} D \psi \exp \left(i S[\psi^{*}, \psi]/\hbar \right) \end{equation}
With
\begin{equation} S[\psi^{*}, \psi] = \int d^4 x \mathcal{L}. \end{equation}
So my first thought was that this should equivalently be the 2-point function $G(q', t', q, t)$
\begin{equation} G(q', t', q, t) = \int D \psi^{*} D \psi \exp(i S[\psi^{*}, \psi]/\hbar)\psi^{*}(x', t') \psi(x, t). \end{equation}
And now, since the integral we are looking at seems to be Gaussian, what we get is that
\begin{equation} G = \frac{1}{i \hbar\partial_t + \frac{\hbar^2}{2m}\Delta-V(x)}. \end{equation} (Of course understood in a distributional sense.)
Now, this seems to be different, then what we had before, on the one hand, we have that $K(q', q, t'-t)$ fulfills the Schröedinger equation in both argument, i.e
$$i\hbar\partial_t K(q', t', q, t) = H K(q', t', q, t).$$
As a result in a distributional sense, we should find:
$$G^{-1} K = 0.$$
As a consequence, we don't have $$K = G.$$
So I guess I have the following questions:
Is it indeed possible to derive the first version of the path integral from the field-theoretic one (the second)?
If the answer to question 1 is no, doesn't that then mean that the path integral and the second quantization approach give different results?
If the answer to 1 is yes? How does it work and did I make a mistake in my assumption?
