112
Let's consider it case by case:
Case 1: Charged particle is at rest. It has an electric field around it. No problem. That is its property.
Case 2: Charged particle started moving (it's accelerating). We were told that it starts radiating EM radiation. Why? What happened to it? What made it do this?
Follow up question: Suppose a charged particle is placed in uniform electric field. It accelerates because of electric force it experiences. Then work done by the electric field should not be equal to change in its kinetic energy, right? It should be equal to change in K.E + energy it has radiated in the form of EM Waves. But then, why don't we take energy radiated into consideration when solving problems? (I'm tutoring grade 12 students. I never encountered a problem in which energy radiated is considered.)
How do moving charges produce magnetic field?
claws
  • 7,493
5 Answers5
89
A diagram may help:
Here, the charged particle was initially stationary, uniformly accelerated for a short period of time, and then stopped accelerating.
The electric field outside the imaginary outer ring is still in the configuration of the stationary charge.
The electric field inside the imaginary inner ring is in the configuration of the uniformly moving charge.
Within the inner and outer ring, the electric field lines, which cannot break, must transition from the inner configuration to the outer configuration.
This transition region propagates outward at the speed of light and, as you can see from the diagram, the electric field lines in the transition region are (more or less) transverse to the direction of propagation.
Also, see this Wolfram demonstration: Radiation Pulse from an Accelerated Point Charge
14
The electrons intrinsic properties are their electric charge and their magnetic dipole moment. So the electron has two fields around it. The magnetic field is observable if one put a magnetizable material into an external magnetic field. Often the magnetization of the material holds for a while, which is explained by the alignment of the magnetic dipole moments of the subatomic constituents.
If one observe an electron beam in a vacuum chamber hardly one will observe that the electrons slow down (except the change of velocity and direction from the earths gravitation). Since there is no decrease of the speed of a constant moving electron there wouldn't be any loss of energy, hence the electron does not radiate. So you are right that only particles under acceleration radiate.
How an why do accelerating charges radiate electromagnetic radiation?
Accelerated charges radiate and they do this in portions, in the past called by Einstein quanta and later called photons. Every photon - as well as the emitting particle - has an electric field component and a magnetic field component and that is why such radiation is called EM radiation.
Why EM radiation occurs?
Suppose you have to slow down a car. Not having EM radiation you would be able to stop your care only by transferring your kinetic energy to another body, be this another massive body or a rotating disc for example. To our luck the loss of energy in every energy transfer happens at any case. So for a why question the answer has to be because nature works this way. The better questions are how something happens. The answer how would be an explanation on a more detailed level (including new hows) as the observation level.
How EM radiation occurs?
There is a phenomenon in nature called the Lorentz force. As soon as an electron moves inside a magnetic field and if the electrons direction of movement is not parallel to the north-south direction of the magnetic field then the electron gets deflection in the direction perpendicular to both directions of the electrons movement and the magnetic field.
An external constant magnetic field does not contribute (put in) energy for the deflection of the electron. Means, one can let through the magnet device electrons as long as he wants, the magnetic device does not weaken. So the reason for the deflection and the escorting EM radiation from the electron has to lie in the electron and its kinetic energy (an electron in rest to the external magnetic field won't be deflected.)
I started with the statement that an electron has a magnetic dipole moment. Coming into an external magnetic field the electrons magnetic field gets aligned to this external field. At the same time the photon emission happens. If we suppose that during the alignment process the radiation of the photon happens, this will disbalance the alignment again And - because the photon has a momentum - the electron gets pushed against the direction of the photon emission which is in accordance with the observation radially outwards directed.
Now we have an effective chain: alignment - photon emissio - deflection - again alignement - ... By this the electron lose kinetic energy and moves in a spiral path until it stops. In detail the spiral path is a path of tangerine slices.
HolgerFiedler
  • 10,980
Accelerating charges don't have to radiate. Look at an electron at rest on the earth (or constantly accelerating for a long time). It will not radiate. The radiation acceleration formula such as Lamor's only hold for particles with changing acceleration - like a sinusoidal movement.
See for instance Feynman: From http://www.mathpages.com/home/kmath528/kmath528.htm
For example, in Feynman's "Lectures on Gravitation" he says "we have inherited a prejudice that an accelerating charge should radiate", and then he goes on to argue that the usual formula giving the power radiated by an accelerating charge as proportional to the square of the acceleration "has led us astray" because it applies only to cyclic or bounded motions.
Tom Andersen
  • 1,428
The second problem is quite tough. J. D. Jackson comments, in the introductory remarks of his chapter on 'Radiation Damping, Classical Models of Charged Particles', that we know how to solve classical electrodynamics problems in two ideal conditions - a) given charge and current densities, how to compute the fields and b) given the fields, how to find the motion of charged particles in their presence. When charged particles accelerate, they do produce radiation which in turn affects the motion of all other charged particles. However, that problem is, Jackson says, still unsolved.
Coming to the first problem, if you calculate $\vec{E}$ and $\vec{B}$ for a moving charged particle, you will see that they depend on the acceleration $\vec{a}$ of the charged particle. Now calculate the Poynting vector $\vec{S}$. You will observe that $\vec{S}$, depends on acceleration but not velocity. Integrating it to get power radiated gives the famous Larmor formula. You may want to refer to Griffiths' chapter on 'Electromagnetic Radiation'.
Amey Joshi
  • 2,310
-1
I like to offer this simple mechanical explanation that doesn't seem to suffer the problems often discussed in the literature. The universe is made of radiation which is another word for energy. Radiation condenses to become e-p pairs with a latent heat c^2, taken from Einstein E=m c^2. Radiation moves at the constant speed c, obeys conservation of momentum and carries mechanical and electromagnetic attributes. We have the usual E, H force fields giving rise to the Poynting vector S=E^H and to momentum; p=S/c^2 and energy; e=pc per unit volume. Add radiation to matter/condensed radiation, and get an increased speed. Thus accelerating charged matter absorbs energy/radiation that appears as motion. If you then force this mass to decelerate, it looses its energy in the form of emitted radiation. This means only decelerated particles emit radiation, loose energy and stop eventually. But we need to spend energy to accelerate a rotating electron in particle accelerator as it looses energy via radiation. This is not the full picture. The pulsed force of the electric field in the accelerator gives energy to the electron and increases its speed and energy. The magnetic field then deflects the moving electron causing it to change speed direction- acceleration and radiate as a result. So radiation is again due to deceleration. The same happens if fast charged particles enter a liquid for example and loose speed.. they decelerate and radiate. Note that this picture is true even when one billiard ball hits another to move it. The particles of the balls never actually touch- the weld if they do. It is the electrostatic force that become strong at very small distances and pushes the other ball to move. But a changing electric field is an electromagnetic field and radiation is involved at the end. So the decelerating ball looses radiation that is absorbed by the non moving ball, gaining momentum and speed- momentum is conserved as we know. This way we don't violate any known conservation law and there is no question of charges acting on their own fields and producing infinities.
Riad
  • 583
