I have been recently studying QM and I have encountered the case of a free particle. I understood that a free particle travels in the form of a wave packet where we get $$\psi (x) = \frac{\int_{-\infty}^{\infty} \phi (k) e^{ikx} dk}{\sqrt {2 \pi}}$$ Now given $\psi (x,0)$ I can find $\psi (x,t)$ now we are required to find the probability density of the wave function. I think it should be $\psi ^*(x,t)\psi (x,t)$ but the solution given does $\phi^*(k,t)\phi(k,t)$ and I am confused. Added to this, we are also given momentum of the particle is $2\hbar k$ but I have no idea where we need to use this value or if it has any significance or not. Also we are required to find the mean energy and I did the normal way: $\int_{-\infty}^{\infty}\psi^* (x) H \psi (x)$ but the answer does not match. Am I interpreting something wrong about the free particle? Please help, I am in real confusion would be glad for some hint.
I found this link where it says $\phi(k)$ is the probability amplitude of momentum of the free particle, but wont we find the expectation value of momentum of the particle by this formula $$\int_{-\infty}^{\infty}\psi^* (x) \frac{-i\hbar d}{dx} \psi (x)~?$$ Probability density for momentum in Quantum Mechanics
To be precise: I am posting the question statement here:
At time =0, a free particle in quantum mechanical state is described by the wave function ()=$\sqrt{\frac{\alpha}{\pi}}e^{\frac{-\alpha x^2}{2}}$.
(a) Find the probability density of the particle with momentum 2ℏ at any time t. Here, k is the wave vector.
(b) Find the mean energy of the particle at any time t.
Note: This is not a HW question. Rather a question that came in our college exam.
Let me provide you some insights into your problem.
  1. Why are we doing $\phi(k, t)^*\phi(k, t)$ instead of doing the normal $\psi(x, t)^*\psi(x, t)$? This is simply because $\psi(x, t)^*\psi(x, t)$ represents the probability density of particle being found in a given position eigenstate. In simpler terms, being found at a particular position in the one- dimensional space. But, if you read your question carefully, it is asking you to find the probability of being found in a momentum eigenstate. So, we jump ships to the momentum space. Here, is where the Fourier transform and Inverse Fourier tricks jump in. Recall the postulates of Quantum mechanics and you will find that the square of the coefficients in the expansion of an eigenfunction in terms of the eigenvectors of an observable represent the probability of being found in that eigenstate of the observable. So, doing $\phi(k, t)^*\phi(k, t)$ is correct apart from some inherent constants which you can find out easily if you look up Fourier transform in any standard text.
  2. This is much more trivial and easy to find out if you look carefully. Your wavefunction is not normalized so your formula will not work. Normalize first and then try using that formula or simply do $$\langle E\rangle=\frac{\int_{-\infty}^{\infty}\psi^*\hat H\psi dx}{\int_{-\infty}^{\infty}\psi^*\psi dx}$$
