What is the physical significance of having a wavefunction with a discontinuous derivative? Sometimes we impose continuity of the derivative in order to find values of unknown parameters and it's helpful. But sometimes it's not required and so it seems arbitrary.
Asked
Active
Viewed 191 times
The relation of the first derivative of the wave function is meant to keep the flux of propability constant across the interface. Therefore, if the effectice masses are different across a heterojunction ($m_1$ at left and $m_2$ at right), the contiuity of flux leads to the following relation across a heterojunction at $x = x_0$: $$ \frac{1}{m_1}\frac{\partial \Psi}{\partial x}\Big\vert_{x_0^-} = \frac{1}{m_2} \frac{\partial \Psi}{\partial x}\Big\vert_{x_0^+} $$
If there is a $\delta(x-x_0)$ potential at the boundary, it will involve in the continuity of flux throught the Shr$\ddot{\text{o}}$dinger equation.
ytlu
- 4,354
-2
Continuity of wave function is essential for finding momentum, momentum is the first derivative of wave function.
hat
- 48
