Hydrodynamic equilibrium would help to understand many things. Once you get to it - many fluid laws can be resolved, including Bernoulli's principle and Archimedes buoyant force. If there comes fluid acceleration due to ANY cause - it results in pressure difference too. This can be generalized in general fluid hydrodynamic equilibrium law :
$$ -\nabla P + \rho\, \frac {dv}{dt} = 0$$
Consider this schematics :
In case (a) fluid acceleration results because unit mass $M$ behind is greater than unit mass $m$ being pushed by it. In case (b) acceleration of unit fluid mass is simply due to Earth gravity.
In both cases acceleration of unit mass produces a pressure gradient, so (a) and (b) are technically equivalent situations.
EDIT
As a bonus for your development of physical intuition. It's interesting to note that movement of people crowd in room under extreme conditions,- such as fire in room,- can be modeled as pseudo-fluid. If people without order tries to rush to nearest exit(s) fast and then pushes each other in the process blindly, then this crowd action results in a great pressure upon those poor people who are in between doors, or near to it. Because only couple of humans can fit through the doors, but behind them are many people wanting the same (so $M > m$ principle). This results in movement acceleration and,- pity,- injuries in some of them. That's why we need strict order leaving such areas - to dismiss crowd pseudo-flow behavior. HTH !
