I'm trying to show the Galilean covariance of the (time-dependent) Schrödinger equation by transforming as follows:
$$ \left\{\begin{eqnarray}\psi(\vec{r},t) &=& \psi(\vec{r}'-\vec{v}t,t),\\ \frac{\partial\psi(\vec{r},t)}{\partial t} & = & \frac{\partial\psi(\vec{r}'-\vec{v}t,t)}{\partial t}-\vec{v}\cdot\vec{\nabla}_{r'}\psi(\vec{r}'-\vec{v}t,t)\\ \vec{\nabla}_{r}\psi(\vec{r},t)&=&\nabla_{r'}\psi(\vec{r}'-\vec{v}t,t)\end{eqnarray}\right. $$ Which gives: $$ i\hbar\left[\frac{\partial}{\partial t}-\vec{v}\cdot\vec{\nabla}_{r'}\right]\psi(\vec{r}'-\vec{v}t,t)=\left[-\frac{\hbar^2}{2m}\nabla_{r'}^2+V(\vec{r}'-\vec{v}t,t)\right]\psi(\vec{r}'-\vec{v}t,t) $$
Now, supposedly, using the unitary transformation: $$ \psi(\vec{r}'-\vec{v}t,t)\to \psi(\vec{r}',t)\exp\left[\frac{i}{\hbar}m\vec{v}\cdot\vec{r}'+\frac{i}{\hbar}\frac{mv^2}{2}t\right], $$
it should be possible to recover the original form of the Schrödinger equation if there is no potential. When trying this, however, I can't seem to make it work. Is it just algebra or am I missing a crucial step here?
My lecturer also hinted that there was a physical reason that there may be no potential for Galilean invariance to hold. What is this reason and how can it intuitively be seen?
Mauricio
  • 6,886
Spurious Eigenstate
  • 1,458
  • 25
I'm not convinced that your transformations are correct. This is one place where it is important, if $x=x'-vt$, to distinguish between $$ \left(\frac{\partial \psi}{\partial t}\right)_x $$ and $$ \left(\frac{\partial \psi}{\partial t}\right)_{x'}. $$ They are not the same thing. You notation is uclear as to what you are keeping fixed in your partials. I find it it easier to distinguish the derivatives by writing
$$ \xi=x-vt,\\ \tau=t. $$ Then the chain rule gives $$ \frac{\partial}{\partial t}= \frac{\partial}{\partial \tau}-v \frac{\partial}{\partial \xi}\\ \frac{\partial}{\partial x}= \frac{\partial}{\partial \xi} $$ where the derivative wrt $t$ keeps $x$ fixed, and the derivative wrt $\tau$ keeps $\xi$ fixed. Similarly the derivative wrt $x$ is at fixed $t$ and the derivative wrt $\xi$ is at fixed $\tau$. The equation in the frame in which the potential moves past you $$ i\hbar \frac{\partial \psi}{\partial t}=- \frac{\hbar^2}{2m} \frac{\partial^2 \psi}{\partial x^2}+V(x-vt)\psi $$ becomes, in the frame in which it is stationary $$ i\hbar\left( \frac{\partial }{\partial \tau}-v \frac{\partial }{\partial \xi}\right)\psi=- \frac{\hbar^2}{2m} \frac{\partial^2 \psi}{\partial \xi^2}+V(\xi)\psi. $$ You can now absorb the extra $\xi$ derivative into the phase transformation that you mention to find a wavefunction $\tilde \psi(\xi,\tau)$ which obeys $$ i\hbar \frac{\partial\tilde \psi }{\partial \tau}\psi=- \frac{\hbar^2}{2m} \frac{\partial^2 \tilde \psi}{\partial \xi^2}+V(\xi)\tilde \psi, $$ in which the only change in the Schroedinger equation is in the time dependence of the potential.
I think I have a minus sign in the convective time derivative compared to your transformed equation.
This transformation is discussed in Baym's quantum mechanic textbook.
mike stone
  • 58,971
  • 53
  • 158
In his elementary book on Quantum Mechanis, "INTRODUCTION TO THE QUANTUM THEORY", David Park demonstrates the invariance of the Schroedinger equation under Galilean Transformations. That material is presented in Appendix 3.
I suggest you give this a look.
M. L. Sloan --- retired theoretical research physicist
