I've been dealing with annihilation operator recently where you can see related information
and
for definition.
Correction made by Valter Moretti and J.G.'s answer, there is no contradiction.
$$ \begin{align} i \hbar \frac{\mathrm{d}}{\mathrm{d}t} \left(a \left| \psi(n,t) \right\rangle \right) & ~=~ i \hbar \frac{\mathrm{d}}{\mathrm{d}t} \left(\sqrt{n} \left| \psi(n-1,t) \right\rangle \right) \\[5px] & ~=~ H \sqrt{n} \left| \psi(n-1,t) \right\rangle \\[5px] & ~=~ E_{n-1}\sqrt{n} \left| \psi(n-1,t) \right\rangle \end{align} \,.$$
and \begin{align} i\hbar\frac{d}{dt}(a|\psi(n,t)\rangle) & =i\hbar\frac{d}{dt}(a)|\psi(n,t)\rangle+a(i\hbar\frac{d}{dt}|\psi(n,t)\rangle) \\[5px] & =i\hbar \cdot iwa|\psi(n,t)\rangle+a(H|\psi(n,t)\rangle) \\[5px] & =-\hbar w a|\psi(n,t)\rangle+a(E_n|\psi(n,t)\rangle) \\[5px] & =(E_n-\hbar w)a|\psi(n,t)\rangle\\[5px] & =E_{n-1} a|\psi(n,t)\rangle\\[5px] & =E_{n-1} \sqrt{n}|\psi(n-1,t)\rangle \end{align}
Notice $\frac{d}{dt}(a)\neq 0$ despite the fact that $a$ in matrix represtation is a constant matrix.
J.G.
  • 25,615
The problem with your first answer is the identity (I prefer to modify notations) $$a \psi_n(t) = \sqrt{n} \psi_{n-1}(t)\:.\quad (false \:\:if \:\:t\neq 0)\tag{1}$$ This is false if $t\neq 0$ (it is trivially true for $n=0$, but I assume $n\neq 0$ henceforth).
Since $\psi(t) := e^{-itH/\hbar} \psi$, the identity above can be expanded as $$a e^{-itH/\hbar} \psi_n = \sqrt{n} e^{-itH/\hbar} \psi_{n-1} \quad(false \:\:if \:\:t\neq 0)\:.$$ In fact, both sides can be separately computed, $$a e^{-itH/\hbar} \psi_n = a e^{-itE_n/\hbar} \psi_n= e^{-itE_n/\hbar} a\psi_n= e^{-itE_n/\hbar} \sqrt{n}\psi_{n-1} = \sqrt{n}e^{-itE_n/\hbar} \psi_{n-1} $$ whereas $$\sqrt{n} e^{-itH/\hbar} \psi_{n-1} = \sqrt{n} e^{-itE_{n-1}/\hbar} \psi_{n-1}\:,$$ and $$\sqrt{n}e^{-itE_n/\hbar} \psi_{n-1} \neq \sqrt{n} e^{-itE_{n-1}/\hbar} \psi_{n-1}$$ because $$E_n\neq E_{n-1}\:.$$ The fundamental reason of the failure of (1) is that $a$ and $e^{-itH/\hbar}$ do not commute. It it were $$a e^{-itH/\hbar} = e^{-itH/\hbar} a\:,$$ then we would have $$\langle \psi_n |a e^{-itH/\hbar}\psi_m \rangle = \langle \psi_n | e^{-itH/\hbar} a \psi_m\rangle$$ i.e. $$\langle a^*\psi_n | e^{-itH/\hbar}\psi_m \rangle = \langle e^{itH/\hbar}\psi_n | a \psi_m\rangle\:.$$ taking the time derivative for $t=0$, $$\langle a^*\psi_n | H\psi_m \rangle = \langle H\psi_n | a \psi_m\rangle\:,$$ so that $$\langle \psi_n | aH\psi_m \rangle = \langle \psi_n | Ha \psi_m\rangle\:,$$ so that $$\langle \psi_n | (aH-Ha)\psi_m \rangle = 0$$ namely, since the Hermite functions $\psi_n$ span a dense space, $$aH\psi_m= Ha\psi_m\:.$$ By linearity, we would have $$aH= Ha\:.$$ at least restricting the domains to the span of Hermite functions $\psi_n$. The identity above is false in view of the commutation relations of $a$ and $a^*$ and $H = \hbar \omega (a^*a + I/2)$ over the said space.
Coming back to your question, the correct result is the second one.
You have to be careful not to mix up implications specific to different pictures. For example, $\partial_t\langle m|a|n\rangle$ doesn't imply $\dot{a}=0$ in the Heisenberg picture because $|n,\,t\rangle=\exp -i\omega_n t|n,\,0\rangle,\,\omega_n:=\frac{E_n}{\hbar}$. While $\dot{a}=0$ in the Schrödinger picture, it can be shown $\dot{a}=-i\omega a$ in the Heisenberg picture, where the Hamiltonian is $-\frac{\hbar^2}{2m}\partial_x^2+\frac{m\omega^2}{2}x^2$. I'll give two proofs; there are plenty of others.
The first is one I mentioned in a comment: since $\partial_t|n\rangle=-i\omega_n|n\rangle$ and $a=\sum_{n\ge 1}\sqrt{n}|n-1\rangle\langle n|$, $\dot{a}=-i(\omega_n-\omega_{n-1})a=-i\omega a$.
Another approach uses $\dot{x}=\frac{p}{m},\,\dot{p}=-m\omega^2 x,\,a=\frac{m\omega x+ip}{\sqrt{2m\hbar\omega}}$.
J.G.
  • 25,615
