I'll illustrate my question with a textbook picture:
Why can't it be discontinuous there? No obvious answer appears to me here, unlike why $\psi$ itself can't be continuous, hopefully? In my view, it's because at the region where there is a jump, it will have two probabilities at once for a single outcome (which is nonsense), but that doesn't illuminate my titular question.
sangstar
  • 3,280
If we look at the 1D time-independent Schrödinger equation we would see,$$-{\hbar^2\over 2m}\psi''(x) + [U(x) - E]~\psi(x) = 0.$$This dependence on the second spatial derivative of $\Psi$ means that a discontinuity in $\psi'(x)$ is an infinite $\psi''(x)$ and only happens at places where $U(x)$ goes to infinity, too, so that the two infinities can compete in a way that can balance out to give zero.
One can extend this reasoning somewhat to include more dimensions of space or a dimension of time, of course; one finds for example that a discontinuous $\Psi''(x, t)$ must either coincide with an infinite $U(x)$ or else must cause $i\hbar \dot\Psi$ to go to infinity at that point, so you've got a complex number circling the origin with infinite frequency.
CR Drost
  • 39,588
The quantum mechanical momentum operator is: $$p=\frac{\hbar}{i}\frac{\partial}{\partial x}.$$
This means that if you were given a wave function $\psi$ where $\psi'$ were discontinuous, you would have points where this momentum operator is not defined. If you have points where this operator is not defined, you are unable to calculate $$\langle p \rangle=\frac{\hbar}{i}\int\psi^*\frac{\partial}{\partial x}\psi dx$$...Generally we want physical systems to have well defined momenta.
enumaris
  • 4,154
