From the wikipedia article, for a Gaussian integral of an analytic function we have that
This is equivalent to the Wick theorem when $f(x)$ is a polynomial.
Now I'm trying to obtain a similar formula when there is a linear term in the Gaussian (ie the Gaussian has a nonzero mean).
My guess is that $$ \int f(x) \exp \left( - \frac{1}{2} x^T A x + B^T x \right) d^n x = \\ = \sqrt{\frac{(2 \pi)^n}{\det A}} \exp \left[ \frac{1}{2} \left( B^T + \frac{\partial}{\partial x_i} \right) A^{-1} \left( B + \frac{\partial}{\partial x_j} \right) \right] f(x) \bigg|_{x=0} \tag{2}$$
but I can't prove it. Is this equation correct? How can I prove it?
psmith
  • 183
The case with the linear term is obtained from the original one by a simple shift, i.e. the substitution $$ x = X + A^{-1} B $$ Substitute it to the exponent in your more general integral: $$ -\frac 12 x^T A x + B^T x = -\frac 12 (X^T+B^T A^{-1}) A(X+A^{-1}B)+B^T (X+A^{-1}B)=\dots $$ I used $A=A^T$. Now, all the terms that are schematically $BX$ i.e. linear in $X$ cancel: the coefficient is $-1/2-1/2+1=0$. The remaining terms give $$ - \frac 12 X^T A X + \frac 12 B^T A^{-1} B $$ The coefficient $+1/2$ in the second term came from $-1/2+1$. The second term only gives a simple factor (the exponential of that), and it's a part of your result – except that the last $B^T$ in your result should be simply $B$.
The hard, quadratic/Gaussian part of the expression may be rewritten in the Wick way from your first identity. It could be enough if you were satisfied with the evaluation of the $x$-derivatives not at $X=0$ but at the right original value $x=0$ which means, thanks to my substitution $$ X = -A^{-1}B. $$ However, if you want to use the values of the derivatives at $X=0$, you have to Taylor-expand the shift operator from $X=0$ to $X=-A^{-1}B$. The shift is the operator $$ \exp(B^T A^{-1} \frac d{dx}) $$ which is exactly what you get from the mixed terms in your guessed exponent, up to an overall sign perhaps that you will surely be able to catch correctly.
Luboš Motl
  • 182,599
Lubos Motl has already provided a correct answer. This answer uses a different approach in the spirit of perturbation theory with $j$-sources:
$$\begin{align}\int_{\mathbb{R}^n} \! d^nx ~f(x)~&e^{-\frac{1}{2}x^TAx +j^Tx}\cr ~=~~& f\left(\frac{\partial}{\partial j}\right) \int_{\mathbb{R}^n} \! d^nx ~e^{-\frac{1}{2}x^TAx +j^Tx}\cr ~\stackrel{\begin{matrix}\text{Gauss.}\\ \text{int.}\end{matrix}}{=}&C~ f\left(\frac{\partial}{\partial j}\right)e^{\frac{1}{2}j^TA^{-1}j}\cr ~\stackrel{\text{Taylor}}{=}&\left. C~ e^{\left(\frac{\partial}{\partial j}\right)^T \frac{\partial}{\partial x}}f(x)\right|_{x=0}e^{\frac{1}{2}j^TA^{-1}j}\cr ~=~~&\left. C~ e^{\left(\frac{\partial}{\partial x}\right)^T \frac{\partial}{\partial j}}e^{\frac{1}{2}j^TA^{-1}j}f(x)\right|_{x=0}\cr ~\stackrel{\text{Taylor}}{=}&\left. C~e^{\frac{1}{2}\left(j+\frac{\partial}{\partial x}\right)^T A^{-1} \left(j+\frac{\partial}{\partial x}\right)} f(x) \right|_{x=0},\end{align}\tag{A}$$
where the constant
$$C~:=~\sqrt{\frac{(2\pi)^n}{\det A}},\tag{B}$$
where $A$ is a symmetric $n\times n$ matrix with positive-definite real part ${\rm Re}(A)>0$, where $f$ is an analytic function, and where we have used the Taylor formula $$f(a+x)~=~ e^{a^T\frac{\partial}{\partial x}}f(x)\tag{C}$$ twice.
Eq. (A) is OP's eq. (2) with sources $j\equiv B$. To obtain OP's first eq. remove the sources.
