20
I am using a couple of documentation files in LibreOffice (.odt) format. Normally, I access them with LibreOffice Writer of course. But there are times when I can only connect to the site with a text terminal.
I am wondering if there is a terminal-based tool that can show me the contents of these files in approximate correct format? (The files mainly contain simple text, bullet lists, and a few 1x1 tables, so it's relatively simple stuff in terms of formatting.)
P.S. This question is not about starting LibreOffice itself from the command line (which is anwered here).
rookie09
  • 303
libreoffice provides a --convert-to option which can be used to convert a document to e.g. text or html:
  • convert input.odt to input.txt:
    libreoffice --convert-to "txt:Text (encoded):UTF8" input.odt
  • convert every .odt in the current directory to .html:
    libreoffice --convert-to "html:XHTML Writer File:UTF8" *.odt
  • convert every .ods in the current directory to .csv:
    libreoffice --convert-to csv *.ods
The output can be opened with the pager or terminal browser of your liking: less, most or w3m to list just three.
dessert
  • 40,956
22
There is a tool called odt2txt that can convert odt to txt.
Compared to libreoffice I can see two benefits:
  • Lightweight if you don't have libreoffice installed (e.g. on a server)
  • It can print to stdout for direct viewing of files.
Installation:
sudo apt install odt2txt
Then you can directly view an odt:
odt2txt document.odt | less
pLumo
  • 27,991
12
LibreOffice has a --cat option which exists in version 5.1 but not 4.2. Not sure exactly when it was introduced.
libreoffice --cat "Untitled 1.odt" --headless | less
For more information:
libreoffice --help
Jim K
  • 1,423
Another tool that you can use is unoconv which can convert "between any document format supported by LibreOffice/OpenOffice"
unoconv -f txt my.odt
phuclv
  • 760
