I use LibreOffice Writer a lot, but I really do hate getting around in a GUI, I much prefer the CLI, so is there any way to open a file using LibreOffice Writer through the Terminal?
Asked
Active
Viewed 1.9e+01k times
84
You can do it by
libreoffice --writer file.odt
If it is an odt file, you can open it just by
libreoffice file.odt
Some file formats can be opened by different LO applications, then you need to specify which one to use.
Pilot6
- 92,041
The more general solution is xdg-open. This not only works for LibreOffice documents, but for any file or URL:
xdg-open file-or-url
opens file-or-url using your preferred application.
If you normally work from the terminal, then having alias o=xdg-open in ~/.bash_aliases makes life simple:
o my-document.odt
o https://askubuntu.com
You may then also enjoy sr (surfraw) for rapid web searches from the command-line.
zwets
- 12,770
- 2
- 37
- 46
In case you need to open a file in LibreOffice in read-only mode it's
libreoffice --view file.odt
cardamom
- 63
