As I mentioned there , how can I view documents( ex: .doc,.docx and all other formats ) from the command line ? Is there any way ?
Thank you.
Raja G
  • 105,327
  • 107
  • 262
  • 331
I have been using the following setup in several scripts (especially with version control):
sudo apt-get install unoconv odt2txt     # installs both tools
doc2odt test.doc                         # creates test.odt
odt2txt test.odt                         # displays the contents in the terminal
or for a docx file:
docx2txt test.docx                       # converts docx file
less test.txt                            # read the contents
Works like a charm and you can read your doc files in the terminal. This method is more complex than catdoc but it has the advantage that entries from a bibliographic management system are not displayed in their raw form.
For a LaTex file you can just your favorite terminal text editor to open and read it.
don.joey
  • 29,392
To View word documents from the command line I found one named as catdoc.
to install it sudo apt-get install catdoc
then
catdoc -t filename.doc
You can specify the output format using the -a (text) or -t (LaTeX) option
Raja G
  • 105,327
  • 107
  • 262
  • 331
