On my Ubuntu 17.04 Dell Latitude laptop I use docking station. This station has dedicated connection.
  1. When I dock My laptop into station, It indefinitely shows "connecting" state icon. Like it tries to connect, then resets, then trying to connect again.
  2. When I unplug cable, wait a bit and connect again the connection is up instantly.
It probably happens more often when resuming from sleep. But tried changing BIOS power options to no avail.
It was working fine on Ubuntu 16.10, but I'm not sure if problem arised after 17.04, as other factors changed too.
There is rather old 10/100Mbit switch between laptop and router, maybe connection negotiation takes too long? But network printer connects without problem.
Update: Tried reloading ethernet driver with modprobe -r -v tg3, modprobe -v rg3 and restarting network service too.
running dmesg shows a lot of link up/link down messages:
[92580.119745] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92580.119768] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92580.774047] tg3 0000:09:00.0 eth0: Link is down
[92582.426348] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92582.426351] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92583.368441] tg3 0000:09:00.0 eth0: Link is down
[92585.047635] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92585.047662] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92585.562763] tg3 0000:09:00.0 eth0: Link is down
[92587.207396] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92587.207418] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92588.085716] tg3 0000:09:00.0 eth0: Link is down
[92589.744788] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92589.744816] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92590.706366] tg3 0000:09:00.0 eth0: Link is down
[92592.296863] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[92592.365857] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92592.365860] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92592.365876] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[92593.326975] tg3 0000:09:00.0 eth0: Link is down
[92594.987186] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92594.987212] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92595.947772] tg3 0000:09:00.0 eth0: Link is down
[92597.608392] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92597.608416] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[92598.568514] tg3 0000:09:00.0 eth0: Link is down
[92600.229535] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[92600.229548] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
Wireshark logs when connection is stalled:
No.     Time           Source                Destination           Protocol Length Info
      7 2.660584149    0.0.0.0               255.255.255.255       DHCP     342    DHCP Request  - Transaction ID 0xde0c185d
Frame 7: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
Ethernet II, Src: Dell_39:4b:6e (d0:67:e5:39:4b:6e), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 0.0.0.0, Dst: 255.255.255.255
User Datagram Protocol, Src Port: 68, Dst Port: 67
Bootstrap Protocol (Request)
     12 5.401359750    0.0.0.0               255.255.255.255       DHCP     342    DHCP Request  - Transaction ID 0xde0c185d
Frame 12: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
     35 13.832656290   0.0.0.0               255.255.255.255       DHCP     342    DHCP Discover - Transaction ID 0xb9200f10
Frame 35: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
Bootstrap Protocol (Discover)
Wireshark logs just after reconnecting cable:
     13 12.440180322   0.0.0.0               255.255.255.255       DHCP     342    DHCP Request  - Transaction ID 0xc06e5459
Frame 13: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface 0
     14 12.444870618   192.168.1.254         192.168.1.5           DHCP     358    DHCP ACK      - Transaction ID 0xc06e5459
Frame 14: 358 bytes on wire (2864 bits), 358 bytes captured (2864 bits) on interface 0
Ethernet II, Src: VtechTel_55:61:31 (00:12:2a:55:61:31), Dst: Dell_39:4b:6e (d0:67:e5:39:4b:6e)
Internet Protocol Version 4, Src: 192.168.1.254, Dst: 192.168.1.5
User Datagram Protocol, Src Port: 67, Dst Port: 68
Bootstrap Protocol (ACK)
     15 12.463981621   192.168.1.5           224.0.0.22            IGMPv3   62     Membership Report / Join group 224.0.0.252 for any sources / Join group 224.0.0.251 for any sources
Frame 15: 62 bytes on wire (496 bits), 62 bytes captured (496 bits) on interface 0
Ethernet II, Src: Dell_39:4b:6e (d0:67:e5:39:4b:6e), Dst: IPv4mcast_16 (01:00:5e:00:00:16)
Internet Protocol Version 4, Src: 192.168.1.5, Dst: 224.0.0.22
Internet Group Management Protocol
PeterM
  • 764
A few months ago an automatic update broke my Ethernet suspend/resume after it was working perfectly for 6 months or so. It happened to a few other users here around the same time.
The solution for me was to create a script that gets executed when resuming from suspend:
#!/bin/bash
# NAME: r8169-reset
# PATH: /lib/systemd/system-sleep
# DESC: Reset Ethernet card after suspend, not working automatically
# DATE: Feb ?? 2017. Modified: Apr 30, 2017.
MYNAME=$0
restart_ethernet() {
   /usr/bin/logger $MYNAME 'restart_ethernet(r8169) BEGIN'
   /sbin/modprobe -v -r r8169
   # /sbin/modprobe -v -r mii
   /sbin/modprobe -v r8169
   /usr/bin/logger 'systemctl restart NetworkManager.service (SUPPRESED)'
   /usr/bin/logger $MYNAME 'restart_ethernet(r8169) END'
/usr/bin/logger $MYNAME 'case=[' ${1}' ]'
case "${1}/${2}" in
   hibernate|suspend|pre*)
   resume|thaw|post*)
      restart_ethernet;;
esac
Save the script to /lib/systemd/system-sleep/r8169-reset. Of course change this script name to your actual driver name. Also change the driver kernel module name within the script.
Note the line:
Sometimes simply restarting the network manager is all that is needed and you can try that too.
You'll need sudo powers to save the file. For good measure I always mark these scripts as executable using:
sudo chmod a+x /lib/systemd/system-sleep/r8169-reset
You can check /var/log/syslog to see output from the script.
Hope this works for you.
